1 - 3 of 3 Posts
I've been working on my aunt's 05 sienna. It previously had codes for ignition timing over retarded (I think p0022/p0021) also had a code for random misfire p0300. I replaced all spark plugs, both OCV sensors, and cleaned out OCV filters. This fixed the timing codes however I still have the check engine light flashing but not codes with it now. It flashes under load so if it's at idle and I hit the AC switch, the light starts flashing and engine rpm goes up and down like it wants to die. I've driven it around the block (I know I shouldn't) but it's still not giving me codes so I'm not even sure where to start. There doesn't appear to be any vacuum leaks. There was some oil in spark plug #2 but I figured if it was that cylinder misfiring I'd get a code for it. Any help is appreciated.
jgonzo, looks like no one seems to have had your situation hence no responses. if you fixed the problem kindly post back so others can learn. regards
1 - 3 of 3 Posts
