2005 toyota camry remote
26057 Views 7 Replies 7 Participants Last post by  MEMovaghar
Hey....need some help on finding the remote control programming guide and instructions.
Its has 3 buttons. One with a lock, unlock and trunk release. It also has a panic button on the other side. The dealership is charging me too much just to program it. They want 50 dollars to program it.
The FCC # GQ43VT14T
I need instructions for programming the trunk release and lock and unlock keys?
Thanks
1 - 8 of 8 Posts
run a quick search...this topic has been done several times...
theres a certain code of random interior operations that can be input to program the remote...
Here you go, im feeling nice tonight:
1. Driver door open and unlocked. Key out of the ignition
2. Insert the key and remove 2 times in 5 sec.
3. Close and open driver door 2 times in 40 sec.
4. Insert the key and remove it again from ignition.
5. Close and open driver door 2 times in 40 sec.
6. Insert the key in ignition,
7. Close the door,
8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”)
9. Remove the key
10. Power lock will cycle to confirm
11. For add or rewrite mode within 40 sec of the confirmation,
A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds.
B. within 3 sec press “Lock” button for more than 1 sec and release.
C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice.
Taken from http://www.automotivehelper.com/topic73219.htm
Make sure you really do wait 1 sec for the intervals or it wont work correctly. count out 1 mississippi
Reactions: 1
yes thats the one soohoo
you really have to be on point and exact with it, or it will not work correctly..
this instruction worked great! programmed my remote in seconds from ebay. thanks!!!
Reactions: 1
Bumping an old thread here.
I have a 2002 Camry XLE. I have only one remote now. Planning to get a second one from ebay.
Is the instructions above valid for Gen 5?
Just search on Youtube, there's a few videos. The above list should work.
Mr. M E Movaghar
The FCC # GQ43VT14T
Thanks
1 - 8 of 8 Posts
