I recently purchase this car, runs good but there is an oil leak,after inspecting the source I notice the the previews owner or someone as JB Weld the oil pan to attempt to stop the oil leak, I also notice the the leak is, not coming from the oil pan gasket,the JB Weld was not necessary because the oil leak is coming from above the oil pan and dripping down to the oil pan giving the allusion the the oil pan gasket was leaking.I have the necessary tools to remove the oil pan and the JB Weld, the question is how do I replace the leaking gasket ABOVE the oil pan? does anybody know the name of that part were the second gasket is( above the oil pan see photo ) and if even is possible to replace?
Thanks for replaying.
Dear Toymann, I seen to have the same problem with a leaking second gasket above the oil pan gasket. Could you tell me what the problem was and how you repaired it please?
Regards,
Marc
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
586.9K members
Since 2001
