So my 2006 AWD 6cyl has a graunching noise coming (99% certain) from the outer CV joint on the right front axle. It's audible in low speed motion and can be silenced if I put slight leftward pressure - so not actually turning just sort of loading the vehicle to the left. Noise comes back if you remove left pressure or lean right.
Questions:
1. How much trouble can I expect getting the shaft out of the bearing carrier? Talking about 43045 on the Toyota parts site diagram. No press at home and no easy access once the truck is off the road.
2. The Car Care Nut on Youtube is pretty adamant about not using aftermarket axles on Toyotas. Thoughts? There's a few used ones on Ebay and LKQ that I would at least consider but not sure my local independent shop will install a used part if I take it to them.
3. Aftermarket - FVP seems to be just a reboxer? Toyota want almost $700 for these axles which ain't happening. The local shop has quoted just over $1000 to do both front axles and nothing else. They did say there is no reason to do both at once but to do the right only is 2/3 of the price to do both.
Was initially very tempted to do the job myself, especially since I already have new ball joints, new swaybar bushings and new outer tie rod ends sitting here but I'm just not sure that I'm up to it. Not sure how the shop will feel about "outside" parts but they have done a job for me once before when I brought them a hub and they just said "no warranty" which I was ok with.
Questions:
