Unless something happens, no, the timing chain shouldn't ever need to be adjusted. At 60K miles you might want to consider a drain/refill of your transmission fluid if you haven't done it already. I've got a 2005 and I did mine at 3yr/25K miles and again at 4yr/34K miles. That might be considered excessive to some but it only takes 15 minutes including prep and clean up so I don't mind.
