1 - 6 of 6 Posts
My truck has 112,xxx now and i have not yet replaced the timing belt. Toyota recommends replacing at 100,000 but I was told by a mechanic that I trust that it is OK to wait longer. Any thoughts on how long is safe before I should change it?
About 22,000 miles ago? It should have been changed at 90k. Although I've heard some people have gone 200k without changing it, I wouldn't risk it and would plan on having it done a.s.a.p.
I just changed mine on my 06 tundra double cab 4.7 L 4x4 with 104,000 miles belt was totally shot ,cracks every 1/8 inch it could have gone any time CHANGE IT my water pump was leaking a bit also so I changed it.
ClutchColton
1997 Toyota Avalon
I'm in the process of changing my timing belt on my 06 Tundra with 102k miles. Haynes manual recommended every 80-90k miles. My belt shows no signs of wear. Only changing it for preventative maintenance. I had a 97 avalon that went over 160k miles on one belt and it still looked good as well. :D
I'm not wanting to take chances on this good truck so I'm changing it.
I belt is probably still good but I bet your truck the water pump has started leaking. I would replace it. Why risk the cost of an engine for an easy repair.
Sent from my iPad using Tapatalk
1 - 6 of 6 Posts
