1 - 4 of 4 Posts
· Swiftly
My 2006 Corolla ASCENT "2nd Tear Drop Remote Fob" was struggling to open the Car Doors & light the "its working Red LED" when pressing the Rubber Button, had been getting progressively worse.
So opened the Tear Drop Key Fob & pressed the MicroSwitch directly, the Key Fob worked easily as intended ie its not a flat battery, damaged micro Sw or poor Solder Joint on the Micro Sw.
Button Battery Tested separately = Good
Being a "Single Button" Tear Drop Remote Fob, the button gets twice the button pressing of the alternate two button integral to Key Head Remotes that came on the Conquest & Levin Models, so the "Internal Rubber Button Wears"
So…Fixed it today the same way I did the "1st Tear Drop Remote Fob" a couple of years back & thought I would share because its a common problem……
If yours has the problem of worn internal Rubber Actuator onto the “PCB Mounted Micro Switch” don’t pay the Dealership for NEW Key Fobs & Re-Programming.
Open, inspect then see if the below works for you.
Cosmetics Office supplies Gas Audio equipment Tints and shades
Fig01 Tear Drop Key Security Remote Fob Difficult to use
Peripheral Circuit component Passive circuit component Computer hardware Hardware programmer
Fig02 Key Remote Fob Wear on Rubber Push Button Internal that actuates the PCB Micro Sw
Blue Gas Bumper Automotive tire Metal
Fig03 Use Hole Punch to Punch out two Circles from “Binder Front Plastic Film” or similar, (an Icecream container Lid works also its thicker so you only need one circle not two)
Home appliance Automotive tire Automotive lighting Gas Audio equipment
Fig04 Stick the two Circles Together I used Contact Adhesive (If you use thin Plastic Film
Automotive lighting Automotive tire Rim Gas Auto part
Fig05 Place over the Worn Rubber Push Button Internal
Automotive tire Writing implement Tread Office supplies Tire
Fig06 Re Assemble & it Works as originally intended
Hope the above helps someone else
Rob
· Swiftly
Discussion Starter · #3 ·
It may take you a few more years HP, but it will happen. Common as muck
Rob
· Token Aussie
1998 AE102 sedan, 2006 ZZE122 wagon, 2018 ZRE182 hatch
Rob
On my AE102 it was always the outer rubber part of the button itself that would fall apart (similar style remote but not identical), you ran the risk then of the actual button (the small pad that's part of the switch soldered to the circuit board) falling out. Could have been a result of the inner part of the rubber falling apart which meant that you had to press the button harder (and wore through with time) but it did tend to display wear from the outside first. Neither of my 122 remotes have any sign of wear yet
1 - 4 of 4 Posts
