I have a 2007 Camry LE with the 4cyl and 125,000 mi on it. The sheetmetal and the interior are spotless. The only problem is that when it has sat overnight and I go to start it, there is a cough of oil smoke that goes away almost immediately.....valve guides I am assuming.
My first thought was the replace just the cylinder head. But then I read up on the Gen 6 Camry and from year to year the engines are actually quite different.
I guess I picked a looser in 2007 in that there was something bad about the design of the piston rings.....so why would I put a new cyl head on an engine with
potentially bad piston rings that probably will not last
I also know enough with differences in sensors, etc just popping a 2008 or 2009 engine will not work. Can I get a Reman 2007 engine with a 2009 style rotating assembly & pistons? Otherwise I probably will not bother
