2007 Camry Hybrid Splash Shield Issue
802 Views 2 Replies 3 Participants Last post by  ND Camry Owner
I noticed driving home from work today that my splash shield seems to be hanging down a little bit. I looked underneath and it doesn't seem like the shield is damaged, maybe one of the fastener clips and a bolt is gone.
Anyone know the part numbers for these pieces? I'd like to repair it myself. If that doesn't work, how much does it usually cost to get it fixed at a toyota service place?
Reactions: 1
1 - 3 of 3 Posts
"... splash shield seems to be hanging down a little bit."
We've got a 2007 Toyota Camry Hybrid domestic. If you go to parts dot Toyota dot com, look up
Radiator Support Splash Shield (Right)
Part Number: 5144106060
under area "SUSPENSION CROSSMEMBER & UNDER COVER"
Is that what you're looking for?
There are various parts numbers, I went to a local hardware supply store and tried to source similar fasteners, and even went and got a few from a local junkyard.
Font Triangle Parallel Rectangle Slope
There are clips and screws that hold the engine covers in. You will just need to get under there and see what you need. I would remove one of the screws and then match it up at the hardware store. For the clips, you can get them at the auto parts store. I personally buy a set from eBay or Amazon so I always have a supply of them.
Clip Assortment
1 - 3 of 3 Posts
