Mine did that once about a year ago. I cycled through the inputs (FM1, FM2, CD, AUX, and AM) then turned it off and back on- and it worked fine- and has never happened again. One-time fluke.
Not exactly a technical answer by any means- but it worked in my case.
If you are adventurous, you might try checking the connections on the back of the radio.
Good luck.
Good luck.
