2007 TOYOTA CAMRY 3.5L V6 Radiator | RockAuto
RockAuto ships auto parts and body parts from over 300 manufacturers to customers' doors worldwide, all at warehouse prices. Easy to use parts catalog.
www.rockauto.com
I'll be sure to flush out all the coolant and have the entire system with the Toyota long life coolant. Thanks for the advice!Check the petcock valve and o-ring first. Check that the water pump is not leaking. Check the radiator cap.
Going forward any Toyota you own 2 year drain the radiator and refill with Toyota ultra long life coolant. On my 2AZFE Camrys that takes 1 gallon of coolant. Do that from new and you will likely never have a radiator or water pump go bad while you own the vehicle. For the first 5 years I owned my 2003 Camry I did it each Spring. Then I went to every other year. My Car is almost 18 years old same radiator and water pump it had when it left the factory. My wife's 2007 was my Mom and Dads before I bought it. They never did this and it is on it's 3rd water pump. I bought for her 2 years ago and it only has 105K miles on it now approximately.
Also everytime you change the oil shoot some parts cleaner into the PCV valve just for good measure!
Can you put a thicker one to the car that originally came with a thin one?Thicker Core Denso:
The size of core is 5/8 inch or 1 inch.Not an issue, the mount are the same.
I believe the thicker core is only an 1/8" thicker, which is great for cooling but not an installation problem.
