61 - 65 of 65 Posts
2007 Camry LE
Swapped out the 07 LE steering with a 07 Solara steering with the DISP button. Wired up pin 22 on the cluster to pin 3 on the spiral cable connector. Also wired up pin 9 on the spiral connector to ground. The button doesn't work, not sure why.
iconman where did you find the connector for the hood latch sensor? My 2011 doesnt seem to have this connector but I do have the hood open warning
Would it be hard to replace the steering wheel controls in a 2011 XLE? I feel they are not as bright as they use to be. I am just concerned about triggering the air bag.
I got it figured out for anyone with a 2011 Camry. I used a 2010 XLE cluster and immediately got the hood open error. I discovered that the 2011 does NOT have the hood switch prewired and I had to go direct to the Main body ECU. Connector E7 pin 16. Ground this cable out and the warning is gone.
2007 Camry LE
Today I tried again to get the XLE DISP info to work with no luck. I am using a 2007 Solara steering wheel with the DISP button. The car is a 07 Camry LE.
I connected a wire going from pin 3 on the spiral cable to pin 22 on the cluster. I also connected a wire going from pin 9 on the spiral cable to ground per another member blutracer.
Any help would be appreciated.
61 - 65 of 65 Posts
