Would this one work? AIT Racing® - Zen Style Fiberglass Front and Rear Bumper Covers (Unpainted) (Toyota Corolla 03-08 Rear Bumper Cover)Yes the bumpers are interchangeable. I assume you want the 05 front bumper facelift?
All panels are the same between 03-08. But if you want to add the side skirts from the S, holes will need to be drilled for the clips.
My last question would be, is modding an '07 corolla be worth it or should i just get a miata?There isn't a cheaper alternative. Fiberglass is the cheapest one, but isn't long term solution. Duraflex costs more, but will last longer than fiberglass.
That is an answer you can only answer yourself. It does not take much to compare the two.My last question would be, is modding an '07 corolla be worth it or should i just get a miata?
Miata is always the answerI have a Miata and a Corolla and the Miata is like a racing go cart. Get one!
That or understand that there is not much you really can do to your car but also that this is the car that, if taken care of well, will keep on running while your project car stays broken.Miata is always the answer
Not all project cars are money pits! But hey, a daily driven Corolla can take a lot of abuse and even negligence.That or understand that there is not much you really can do to your car but also that this is the car that, if taken care of well, will keep on running while your project car stays broken.
