1 - 14 of 14 Posts
hi, new to site, im john, I just installed a used engine 07 camry 4cyl, and a new hybrid battery, now front wheels still.off ground, tried to start to run and check all.fluids etc, not getting the ready on dash, not sure what to do now? Any advice?
Can you spare any more details? Recheck all of your connections? Is it recognizing you key or fob? Lock/unlock car....hold fob next to start button? Try another key/fob? Has 12V battery run down in this process?
Discussion Starter · #3 ·
Good morning, it is recognizing the key fob it does lock in unlock the doors the 12 volt battery is fully charged it has 12 and a half volts when I put my meter on it I don't know if the front wheels being off the ground has anything to do with it or not I have double-checked all my connections I believe I have every single thing plugged in I did also check all my fuses they are all good underneath the hood
· Super Moderator
Well, I once had my hybrid up on car lift and tried to start and spin wheels. It started but will NOT engage ICE and wheels.
Maybe it does have something to do with wheels off.
Otherwise, you've done so much work to it that issue can be a many.
I have a 2016 Avalon Hybrid....so I do not know what your dash looks like or what buttons to push.....
Does the key picture come up? just because the doors unlock is not an indicator that the immobilizer is recognizing the key.
What is the state of charge of the traction battery? Pull up different screens on the energy screen. Go through the settings and see if you can find it. Wondering if it is recognizing you pushing on the brake pedal? What lights light up when you attempt to start it? What happens if you just hold the start button in (along with the brake pedal)? (couple times, any port in a storm)
Have any fusible links been blown under the hood?
Look up the search term: Toyota Hybrid no start no ready light
Do a lot of reading. Probably need the Techstream diagnostics. I have it, but my Chinese cable is not recognized, so I cannot get the computer and car to chat together.
Here is a statement that I read on a page:
if you have serviced the hybrid battery most people mess up the insertion of the orange safety plug. You push it in flip up the handle THEN push that handle straight down till it locks.
Snookwhaler would be your man, he hasn't been on for a month, maybe send him a PM.
I do not have enough experience with hybrids to help you, but 40+ years of cars can shove me in the right direction.....meaning that I can sometimes recognize the right trail even though I don't know where I'm going. I could tell you more than one could want to know about 81-83 Nissan Maxima Diesels....hybrids...not yet.
Don't be afraid to look at Prius or other cousins in the Toyota family....look anywhere and everywhere on the web....don't forget to come back and give the final report.
So, let it down on the ground...maybe it knows?
Discussion Starter · #6 ·
I put the wheels back on the ground I think my issue may be in my Hybrid battery I don't know how to check voltage I put my meter on it I'm not getting anything with everything plugged in
Good afternoon, when my friend bought this vehicle the dealership said it needed a brand new battery because it was going bad it also had a bad head gasket and was burning oil he drove it to my house I drove it into my driveway I replaced the Hybrid battery I did not connect it until I was done with the engine then I connected it now nothing is coming on and I cleared all my codes but now I'm getting a p0ae6 oh, I tried to clear it but I cannot I double-check all my connections everything looks like it's plugged into me I don't think I missed anything but for some reason I cannot check the voltage on the Hybrid battery with my meter no matter what I do I'm coming up with nothing unless I'm doing something wrong I'm not familiar with the dash but I'm going to look into that now it's a friend's car it's not mine
Can you check voltage @ traction battery? I do not know the safe way to do it....but it is not like a 12v battery...be careful...650v
Check the service plug and be sure it is seated correctly. It should "click" into position. Even if you think you did it right, check it again. This has been the cause of many no starts and is a simple thing to overlook.
Discussion Starter · #8 ·
Can you check voltage @ traction battery? I do not know the safe way to do it....but it is not like a 12v battery...be careful...maybe 650v?
I place my bets on this:
I did check that many times it is clicking it's all the way down I believe it is within the new battery I put in I do not see a black cable coming out of it where the two cables go on one terminal I believe that may be the problem the 12-volt battery is perfectly fine I have 12 and a half. I just drove this vehicle last week before I change the engine and the battery
Discussion Starter · #9 ·
296803
Discussion Starter · #10 ·
  • I do not have the original battery we had to return that at the time of the Core Exchange I'm just not 100% sure if this battery is supposed to look this way or if it's supposed to have that black cable on the inside like all the other pictures that I see online, this was supposedly sold as a new battery with a 4-year warranty but it's definitely not brand-new that's for sure
Discussion Starter · #11 ·
I did try to check voltage, it didn't read anything,
Did you have the orange thing in place to get a reading from under the cover in the back seat? You could also check @ the orange thing....I think. Here is a video of the whole battery being replaced....in life I sometimes wish I could have seen it again....before I took "it" out or apart. Check to be sure that the low voltage connector is hooked up...just before 6 minutes on the video.
Under the comment of this video....someone said:
FOR ANYONE WATCHING THIS THE LARGE BLACK WIRE ABOVE THE 2 ORANGE HIGH VOLTAGE WIRES IS A 12v POSITIVE WIRE and not a ground. That’s why it has red tape around it. It runs to the under hood fuse box. Do not try to ground it.
The video originator said that the FSM says to unhook the 12V first and then the 2 orange wires to protect the electronics.
Here is a video of a guy with the long cover plate off:
Perhaps the traction battery that you were sold, has an internal connection problem? I originally surmised, that perhaps you had the car apart for 4 to 8 weeks....and I understand that, that is not the case. I wish that I could be of more help, but I have not had any hands on experience. If the traction battery has no charge, then I would contact the seller....they can get "funny" about....well you took my battery apart....and therefore.....I would fetch you a video of someone taking the battery apart to check....but I just said not to....
The traction battery charges the 12V battery....so if you check the large black wire, or the 2 orange wires (with the orange connector installed) I'm thinking that everything that you are checking are hot wires 12v or 276v. So I'm thinking that if you can use your meter, use your tin case/housing as a ground source and see if you get 12v out of the large black wire....and then each of the orange wires....I'm thinking that they are both hot.
Watch @ 4 minutes:
I am not advocating this company, but am including it for the best pictures I have seen....short of being there...
I'll try to look further tomorrow....
1 - 14 of 14 Posts
