1 - 3 of 3 Posts
Hi all,
I am new to the forum here. I have a 2007 Toyota Solara SLE Convertible. Three of my wheels are bent due to hitting various potholes over the past year as well as hitting a curb. I want to replace these wheels with other wheels of the exact same size so that I can use the tires that I already have (since I just bought them) and so that they do not rub on any other part of the wheel well or hub. I have concluded that the size is 17" x 7", that they 5 lug nuts at 114.5 mm. However, I cannot determine how to measure the offset. I have read multiple threads about which offset they are (some say 45 and others say 50). I just need a definitive answer so that I can replace them seamlessly. Its a BUMPY ride right now.
Thanks in advance,
Dan
2007 Camry LE
Solara's 17X7 wheels are 50 offset.
Speedkar99 on YouTube
2003 Camry
50mm offset. Its written on the back of the spoke of the rim.
You can probably find a set of 4 OEM Toyota wheels from other Toyota models (Avalon, Camry, Lexus ES, etc) that are the same size. Newer Camry's with 45mm offset shouldn't be a problem either.
1 - 3 of 3 Posts
