1 - 10 of 10 Posts
Help! We bought a 2007 Tacoma in June of last year. We haven't run into any problems until this week. The truck has been sitting for 2 weeks, and when we went to start it a couple of days ago, the engine won't turn over. Instead, there is a clicking from the engine. Is this the starter? Has anyone else run into these kind of issues? I tried boosting it, but it doesn't make any difference.
About 3 weeks ago, the temperature dropped to -40 for a couple of days. One of those days, the truck wasn't plugged in. Could this have affected something?
Please help!
Crys
start with your battery. make sure it is fully charged. Have the autoparts store do a load test. extreme cold kills batteries that aren't used frequently
Humble Servant
2012 DC PreRun Auto
Insufficient voltage.
Possibly bad battery, possibly bad connections (reducing the charging and dropping the voltage to the starter). I would first check the connections at the battery and starter, the grounds at the chasis and engine. Low voltage at the battery could be bad cell(s) -or could be due to bad connections inhibiting charge. Checking connections is cheap.
Banned
giver a jump..
in our artic weather, parasidic draw will kill the battery over a couple of week period.......
now i would have thought i would have lasted a little longer.
plug the truck in and jump it....
let us know what happens
cheers
Warts
TacoFever
check your tire pressure .. they all have to be the same for the truck to start. :D J/K!!
.. like said above check battery.
rockin' the stock
Mine didn't start today. I'd driven it just the day before and it's been in the seventies. I was, like, WTF, 'cause I was headed to the mizz-all! First, got nothing, though my radio and lights worked, then the clicking. Jumped it with a plug-in battery charger, let'er run for a bit (and went around the block), then left it alone for an hour plus before trying again. It started. I've had the truck since Nov. '05, so I guess it's about that time.
Maybe it was a sign, though; wound up visiting a recovering friend of the family in the hospital instead.
Hopefully a new battery's all you need.
TRD OFF-Road DC
Your double rotating wobbly probably froze up in that cold weather. Your local dealer should be able to get you one to do a quick fix. :lol:
1 - 10 of 10 Posts
