1 - 20 of 31 Posts
Hello,
Finally, i have a truck !! its 2007 Base tacoma V6 4.0 four wheel drive option.
since i have been toyota front wheeler driver i knows the fluid types for Camry, RAV4 and Sienna.
This truck is new to me.
Please advise.
Transmission fluid - I am assuming WS Toyota
don't know about
1. Transfer Case.
2. Front differential
3. Rear differential
your help in matter is greatly appreciated.
My Other Truck
Congrats on your new-to-you truck! The above link should answer all your questions.
Quick answer about fluids in the TC and diffs -- I use Mobil-1 full synthetic 75W-90. If your truck has an optional limited-slip rear diff, you'll need a friction modifier, and some work better than others. We can research that for you if necessary.
Thanks,
As you know i am new to tacoma
all i know is this is base model V6 4.0 with four door and have 2H -4H and 4L switch option.
what is optional limited-slip rear diff ?or how to find.
Thanks in advance.
1995 T100 2WD & 1993 MR2
Put your VIN into this site it willcreate a build sheet for your truck.
LSD diffs were used pretty regularly on the 2005-2008 Tacomas.
I pulled up several using the info you provided and they had lSD's. There is usually a sticker on the rear diff stating Use LSD Oil only.
My Other Truck
There might be a tag on the diff that will tell you. Old-school method, which might work for our trucks, is to jack up the rear of the truck so both back tires are off the ground. In neutral, parking brake off, rotate either tire by hand. If the opposite side tire rotates in the opposite direction, you have an open diff -- no LSD. If it rotates in the same direction as the one you are turning, you have an LSD.
Here's your fluid capacities if you don't already have them. Buy 6 quarts total.
3.0 quarts for rear diff
1.6 quarts for front diff
1.1 quarts for transfer case
Discussion Starter #7
So if I have LSD I have to use LSD additive type fluid only on rear or every one. Front rear and transfer case. Please advise.
boulderskies
2006 Tacoma
hi. exactly where on this site would i put the VIN? thanks for this. its pretty cool if it's complete.
scott
The LSD (limited slip differential) So only in the front and rear diffs. Transfer case uses gear oil like the Mobil 1, 75w-90w
Discussion Starter #11
Market
N. America
Year
04/2007
Make
TOYOTA
Model
TACOMA
Frame
GRN245
Vehicle characteristics
GRADE:BASE:BASE TYPE
DESTINATION:USA:UNITED STATES OF AMERICA
CABIN:DCB:DOUBLE CAB
ENGINE:1GRFE:4000CC 24-VALVE DOHC EFI
GEAR SHIFT TYPE:5FC:ATM, 5-SPEED FLOOR SHIFT
COLOR CODE:3P1
TRIM CODE:FN42
Search Results
VIN*Model codeFromToFrame Characteristics
5TELU4EN..GRN245L-PRADKA09/2004 -04/2008GRN245BASEUSADCB1GRFE5FC
Click here to continue
dont say anything about LSD
LSD was available on the Base 2007's
  ('0707-'1508) GRN245, 265, W(REAR DIFF LOCK) Next >
33275LSEAT, REAR DIFFERENTIAL LOCK SHIFT DETENT BALL SPRING
33275-16010WITH(REAR DIFF LOCK)1$1.27
41039GEAR KIT, DIFFERENTIAL, REAR
41039-34060WITH(REAR DIFF LOCK)1$552.39
41039-34070WITH(LSD)1$255.65
Check for a tag on the rear diff or jack it up and rotate the rear wheels by hand.
"There might be a tag on the diff that will tell you. Old-school method, which might work for our trucks, is to jack up the rear of the truck so both back tires are off the ground. In neutral, parking brake off, rotate either tire by hand. If the opposite side tire rotates in the opposite direction, you have an open diff -- no LSD. If it rotates in the same direction as the one you are turning, you have an LSD."
Is this P/N on that sticker? 41039-34070
If so it's a carrier for a LSD diff.
My Other Truck
LSD is rear diff only (is so equipped) but no LSD in the front diff from the factory.
Discussion Starter #19
so jack up from rear and put in neutral, when i spinning one wheel other side was spinning other way
No LSD Right?
i can use regular 75W90 for front, rear and trans-case?
1 - 20 of 31 Posts
