21 - 31 of 31 Posts
Discussion Starter #24
Mobil 1 75W90 i see with Limited slip friction modifier included
is it okay to use??
05 Tacoma 4x4 DC LB
I agree with Splicer. Just a reminder that when you go to drain the oil out of any of them, loosen the fill plug FIRST. You don’t want to drain the fluid and be unable to get the fill plug loose leaving you stranded without oil in them.
My Other Truck
I'm glad you mentioned that, Moose. I always forget to...... I guess because I just automatically do that without ever thinking about it.
05 Tacoma 4x4 DC LB
I could also warn him to not drain the trans fluid by mistake when he goes to change the engine oil. Hmm, I hope he reads this because that was probably the most common mistake people made with these trucks (second would be asking about the front wheels binding in 4wd).
Discussion Starter #29
Good evening,
today i did change rear differential, Transfer case and front differential fluid.
i used all three places 75W90 by Mobil 1.
What i noticed is front differential fluid color was different then others? Why?
Thanks in advance.
05 Tacoma 4x4 DC LB
No reason except maybe it was never changed and the others were? Or maybe it was changed at a different time with a different brand.
21 - 31 of 31 Posts
