My 2007 Toyota Camry SE has developed and intermittent electric door locking problem. When you try and lock the door from the outside with the key fob, it will intermittently either:
1. beep and lock/unlock all the door
2. beep and lock/unlock some of the door
3. not beep and lock/unlock the doors
4. not beep and lock/unlock some of the door
I have tried 2 different key fob with 3 different sets of batteries, same result.
The inside switch have the same problems (but without the beeping.
When I talked to the dealer, they suggested replacing the PCM/ECM and seeing if this took care of the problem
Does anyone one else have any suggestions?
