1 - 3 of 3 Posts
Hey just wondering how to change the exhaust flange gasket, bolt, spring in 2008 highlander. Any videos or instruction manual. Also please let me know where you bought the parts from.
Super Moderator
1995 T100 2WD & 1993 MR2
The parts can be bought at any auto parts store, nothing special about them.
It's straight forward, unbolt the existing hardware, slide the old gasket out, install the new one and hardware.
Once ya climb under there you'll see it's not a mystery worth a video.
09 V6 Highlander AWD , 15 Corolla LE
Had to replace a donut gasket (the one just after the 'y' pipe) on my 09 Highlander last year .Bought a gasket and bolt set with the springs.
Sprayed some penetrating oil on the bolts and after 30 mins of soaking, was able to easily remove both bolts with a rachet. I could not believe how easy the bolts came off a vehicle that had spent the last 12 years in canadian winters , spending the nights in a heated garage and driving around on salty roads....
I was able to re-use the original bolts so I returned the new ones to the parts store...cost me $8.00 and took less than one hour to do the job...good luck with yours...
1 - 3 of 3 Posts
