Are you going directly to the motor in the drivers door? Or are you cutting the wires at the switch and getting motor side, and switch side?
I have not done mine yet, but have done them in other tacomas without any problems. I always go to each door though. This gives you auto up and down from all switches. If you only do it from the drivers door, you only have auto up from the driver.
I always cut my wires at the switch for the switch and at the motor for the motor.
One other thing, what is the date code on your 530t. I had some problems with some, but it was a while back. There is also a tech document on high to adjust the resistance for the windows. I'll look for it for you.
There was a time I did about 10 530t installs a week. It's died down a lot, but I am very familiar.
Hope it helps,
Paul
Hope it helps,
Paul
