1 - 12 of 12 Posts
Good Morning Toyotanation,
I've been lurking here for a while now, trying to find out what exactly I need to do on my 2009 Toyota Camry SE for it's 10/11th anniversary.
I've owned the car since 2014 and took it over with 33k miles. It has now slightly more than 96k miles and just got new tires - so I am hoping it'll last another 4 or so years for the moderate driving I'm doing (10k miles per year now).
I haven't had the time and money to give the car it's proper 10 year maintenance last year, so I'm hoping this year is the year.
I've identified that the motor has the typical oil burning issue, I recognized it last year during summer but didn't think much of it and just confirmed it last night after reading some more on these great forums. It seems though, that the repair isn't worth it and I would have to live with topping up oil every 1000 miles or so?! The engine is listed as "2.4-L L-4 DOHC 16V"
Other than that, the car runs great and never needed much work (which I've always been grateful for). The vinyl is starting to get a few small rust and water spots that I'm planning to fix soon.
Other than that, I've identified that I should do the following items:
  • Replace Spark Plugs (Planning to do this myself)
  • Alignment checked
  • Transmission Flush + Replace ATF Filter
  • Replace Radiator Hoses
  • Replace Thermostat
If you guys could point me towards other maintenance items needed, that would be wonderful! Really trying to keep this car going for another 4-6 years.
Plenty you can do.
MileageDateTitlePart NamePart ManufacturePart NumberDescriptionPrice
2/8/2013​
ReplaceFloor MatHuskyWeatherbeater 98512Put in new floor mats $ 123.95
2/8/2013​
ReplaceHigh BeamPhilipsVisionPlus 9005Replaced high beams $ 12.58
2/8/2013​
ReplaceLow BeamPhilipsCrystalVision Ultra H11Replaced low beams $ 29.17
7/9/2013​
InstallEngine RebuildToyotaT-SB-0094-11Toyota rebuilt engine with updated pistons and replaced water pump N/A
8/10/2013​
ReplaceHigh BeamPhilipsCrystalVision Ultra 9005Replaced high beams $ 9.99
9/6/2013​
InstallFog LightEbayGenericInstalled fog lights $ 39.99
44,960
2/8/2014​
InstallVent Visor (Sides)WeatherTechDark 82421Installed vent visors $ 99.95
45,100
2/14/2014​
InstallTail LightSpyderLEDALT-YD-TCAM07-LED-RCInstalled LED tail light $ 188.95
45,100
2/17/2014​
InstallFog LightiJDMToy3000K LED H11Installed LED fog light $ 80.99
2/21/2014​
ReplaceFog LightDepoFog Light Cover x2Replaced fog light covers $ 18.88
49,210
6/25/2014​
InstallCold Air IntakeK&N69-8610TTKInstalled cold air intake $ 305.50
49,620
7/8/2014​
InstallReverse LightVLEDLED 5000KInstalled LED reverse light $ 36.74
52,028
9/12/2014​
MaintenanceATF Drain & FillToyotaWorld Standard ATFATF drain and fill N/A
56,451
3/16/2015​
InstallLow BeamMorimotoElite 5000K HID H11Installed HID low beam $ 150.00
59,450
5/23/2015​
ReplaceBatteryO'ReillySuper Start 24REXTOEM battery finally died N/A
64,171
9/20/2015​
ReplaceRear Sway LinkMoogK750011Replaced rear sway links N/A
74,560
9/27/2016​
InstallWindow TintStereo1One35% TintWindows tinted 35% $ 145.00
10/10/2016​
InstallTow LoopRaceQuip897147Installed tow loop on frong bumper $ 30.94
10/10/2016​
InstallTransport HookToyota51968-33020Installed transport hook $ 44.61
74,339
10/11/2016​
ReplaceCoolantToyotaToyota Super Long LifeBusted radiator N/A
74,339
10/11/2016​
ReplaceRadiatorProtechN/ABusted radiator N/A
75,800
11/18/2016​
InstallTires (OEM)BFGoodrichAdvantage T/A SportInstalled tires N/A
75,980
11/28/2016​
InstallHigh BeamMorimoto2-Stoke LED 9005Installed LED high beam $ 90.00
3/1/2017​
InstallVent Visor (Rear)Spoiler KingSPK-244RInstalled rear vent visor $ 28.49
78,273
3/7/2017​
MaintenanceThrottle BodyN/AN/ACleaned throttle body N/A
78,505
3/14/2017​
MaintenanceAir FilterK&NRU-4990Cleaned air filter N/A
78,810
3/27/2017​
InstallStrut BarMegan RacingMR-SB-TCA07FU-1PInstalled strutbar $ 82.98
80,010
4/28/2017​
MaintenanceWindow WiperRainXWeatherbeater 24" 19"Replaced wipers N/A
82,507
8/25/2017​
MaintenanceFuel CleanerTechtronConcentrate PlusAdded fuel cleaner N/A
82,507
8/30/2017​
InstallThrottle ControllerWeapon-R656-112-102Installed throttle controller $ 153.84
82,750
9/4/2017​
MaintenanceOil ChangeMobil 10W-20 & M1-103AOil change N/A
82,750
9/14/2017​
MaintenanceCabin Air FilterFramCF-10285Replaced cabin air filter N/A
83,712
9/25/2017​
DTCEngine CodeN/AP2121Very low throttle, reset throttle controller N/A
83,712
9/25/2017​
InstallVent Visor (Rear)EbayGenericInstalled rear vent visor $ 46.89
83,712
9/25/2017​
RepairThrottle ControllerWireGenericSpliced into arm rest 12v connector N/A
84,569
10/30/2017​
ReplaceDoor Handle CoverToyota69217-06030-B2Old door handle cover was lost, replaced part N/A
11/30/2017​
InformativeFog LightN/AN/AFog lights stopped working N/A
11/30/2017​
ReplaceLow BeamMorimoto5500K H11B XB HIDReplaced HID bulbs with updated version $ 43.77
12/5/2017​
InformativeFog LightN/AN/AElectrical connector near battery has weak connect, replace the connectors N/A
87,163
1/15/2018​
InstallMufflerSpeed DaddySDD-CBEMUTCA07Installed new muffler, replaced and welded new muffler tip $ 91.83
2/10/2018​
InformativeBlower MotorN/AN/AMakes sound when on. N/A
2/13/2018​
InformativeBlower MotorN/AN/ASound disappeared N/A
2/21/2018​
InformativeFog LightN/AN/ARight fog light dead N/A
3/17/2018​
RepairPaintN/AN/AUsed Loctite Rust Neutralizer and Jeff's Paint on deep scratches and rust spots N/A
89,551
3/30/2018​
InstallVent Visor (Rear)LT Sport100000000552-201Installed rear vent visor $ 49.99
89,551
3/30/2018​
InstallVinyl WrapAverySW900-190-0 Gloss BlackVinyl wrapped roof $ 52.00
90,000
4/21/2018​
InstallFloor MatHuskyWeatherBeater 44501Installed cargo mat $ 40.38
90,000
4/21/2018​
90,000
4/21/2018​
ReplaceVinyl WrapAverySW900-190-0 Gloss BlackRemoved vinyl wrap from roof N/A
90,030
4/24/2018​
90,380
4/28/2018​
90,697
5/7/2018​
InstallFog LightMorimotoXB LED (Yell0w Film)Installed new foglight housing $ 185.00
90,697
5/7/2018​
ReplaceLH Fog Lamp CoverMutiple ManufacturersTO2598101 Swapped fog lamp cover $ 2.75
90,697
5/7/2018​
ReplaceRH Fog Lamp CoverMutiple ManufacturersTO2599101 Swapped fog lamp cover $ 2.75
90,697
5/7/2018​
ReplaceRH Inner Fender Splash ShieldMutiple ManufacturersTO1251122 Installed splash shield $ 15.38
92,799
7/6/2018​
ReplaceThrottle ControllerWeapon-R656-112-102Rewired throttle controlller N/A
92,822
7/10/2018​
MaintenanceTire RotationN/AN/AFront to Back N/A
92,822
7/10/2018​
ReplaceTires (OEM)BFGoodrichAdvantage T/A SportReplaced two tires due to plug leaking, T Rated $ 175.30
7/20/2018​
ReplacePCV ValveToyota12204-28030Replaced PCV valve $ 6.31
93,239
7/30/2018​
ReplaceSpark PlugDensoSK20R11Replaced spark plugs $ 22.44
93,355
8/4/2018​
ReplaceBelt TensionerContinental49396Replaced belt tensioner and swapped 85mm bolt for 70mm or 75mm bolt $ 135.79
93,355
8/4/2018​
ReplaceSerpentine BeltContinental4070752Replaced belt $ 17.08
93,578
8/15/2018​
MaintenanceWheel AlignmentFirestoneN/AWheels alighnment, minor issues N/A
94,011
8/26/2018​
InstallRear Window SpoilerSpoiler KingSPK-380RInstalled rear window spoiler $ 125.30
94,085
9/5/2018​
DTCEngine CodeN/AP0137O2 Sensor Circuit Low Voltage Bank 1 Sensor 2 N/A
94,321
9/17/2018​
ReplaceBelt Moulding Assembly FRToyota75710-33130Vinyl wrapped and replaced belt moulding $ 50.45
94,321
9/17/2018​
ReplaceBelt Moulding Assembly RRToyota75730-33130Vinyl wrapped and replaced belt moulding $ 58.54
94,374
9/21/2018​
ReplaceBelt Moulding Assembly FLToyota75720-33130Vinyl wrapped and replaced belt moulding $ 51.99
94,374
9/21/2018​
ReplaceVent Visor (Sides)WeatherTechDark 82421Front visor warranty replacement N/A
94,014
9/23/2018​
InstallLicense PlateWI DMVADW-5433Installed new license plate after car registration $ 194.50
94,014
9/23/2018​
InstallRear Window SpoilerSpoiler KingSPK-380RReinstalled spoiler with new 3M VHB and Lexel adhisive N/A
94,044
9/24/2018​
ReplaceBelt Moulding Assembly RLToyota75740-33130Vinyl wrapped and replaced belt moulding $ 37.46
95,222
10/20/2018​
95,479
11/3/2018​
ReplaceFront Speaker AdaptorScosche SAT69 Replaced front speakers $ 7.99
95,479
11/3/2018​
ReplaceFront Speaker ConnectorsCrutchfield12071034LReplaced front speakers $ 9.99
95,479
11/3/2018​
ReplaceFront SpeakersJBLClub 6520Replaced front speakers $ 49.90
95,479
11/3/2018​
ReplaceRear Deck SpeakerJBLClub 9630Replaced rear deck speakers $ 69.95
95,479
11/3/2018​
ReplaceRear Deck Speaker AdaptorCustom Install PartsB007ZREFCAReplaced rear deck speakers $ 15.99
95,479
11/3/2018​
ReplaceRear Deck Speaker ConnectorMetra72-8104Replaced rear deck speakers $ 6.95
96,479
11/20/2018​
ReplaceRadiator CapTRDPTR04-00000-031.1 bar (16 psi) radiator cap replaced by 1.3 bar (19 psi) radiator cap $ 37.44
97,349
1/18/2019​
InstallInterior Footwell LightingSUPERBRIGHTLEDsWFLS-NW30-BK: 50cm[19.7in] Cool WhiteInstalled wiring harness to the dome light and interior LED footwell lighting $ 47.57
98,021
2/24/2019​
ReplaceInterior Footwell LightingSUPERBRIGHTLEDsWFLS-NW30-BK: 50cm[19.7in] Cool WhiteRewired LR interior LED footwell lighting N/A
98,049
2/27/2019​
InformativeTail LightN/AN/ALR Tail light went out, issue caused by lose wiring N/A
98,049
2/27/2019​
InstallRear Deck SpeakersN/AN/APlaced to sheets of foam due to rear deck rattle during heavy bass songs $ 3.84
98,426
3/15/2019​
InstallPocket PodCoverCraftTO1012CHInstalled pocket pod on trunk lid $ 54.78
98,450
3/20/2019​
InformativeATF Oil SealN/AN/ARight oil seal leaking N/A
98,450
3/20/2019​
InformativePower SteeringN/AN/APower steering hose leaking near resovior N/A
98,450
3/20/2019​
InstallExhaustMegan RacingMR-CBS-TCA07L4Installed exhaust system $ 399.99
98,450
3/20/2019​
MaintenanceATF FluidToyotaWorld Standard ATF5 quarts of Toyota World Standard ATF $ 46.42
98,450
3/20/2019​
MaintenanceATF Pan GasketToyota35168-21020Replaced ATF pan gasket $ 11.42
98,450
3/20/2019​
MaintenanceATF Strainer (Filter)Toyota35330-08010Replaced ATF strainer $ 42.38
98,450
3/20/2019​
MaintenanceATF Strainer SealToyota90080-30077Replaced ATF strainer seal $ 4.71
98,585
3/23/2019​
MaintenanceWindow WiperRainXLatitude 24" 19"Replaced wipers N/A
98,585
3/24/2019​
98,858
4/6/2019​
DamageRR Caliper Slide PinN/AN/ARR caliper slide pin and boot is damaged and needs to be replaced N/A
98,858
4/6/2019​
MaintenanceBrake LubricationPermatexSilicone Ceramic Extreme 24128Lubricated new brake hardware and slide pins N/A
98,858
4/6/2019​
MaintenanceRear Sway LinkAMSOILSynthetic Multi-Purpose Grease NLGI #2Lubed rear sway links N/A
98,858
4/6/2019​
ReplaceFront Brake PadWagnerThermoQuiet QC1293Replaced front pads $ 28.89
98,858
4/6/2019​
ReplaceFront Brake RotorWagnerBD126407EReplaced front rotors $ 73.58
98,858
4/6/2019​
ReplaceRear Brake PadWagnerThermoQuiet QC1212Replaced rear pads $ 27.79
98,858
4/6/2019​
ReplaceRear Brake RotorWagnerBD126489EReplaced rear rotors $ 49.58
99,044
4/20/2019​
InformativeBrakesN/AN/ABrake schreeching noise N/A
99,044
4/20/2019​
99,044
4/20/2019​
99,252
4/27/2019​
MaintenanceBrake Fluid FlushWagnerFC133301 DOT 5.1Flushed brake fluid with Wagner DOT 5.1 N/A
99,252
4/27/2019​
ReplaceRear Bottom Rear Caliper PinsWagnerH14160Replace rear bottom caliper pins $ 11.74
99,252
4/27/2019​
ReplaceRight Rear Caliper Pin BootsWagnerH18100 Replace caliper pin boots $ 4.43
99,276
4/29/2019​
InformativeECM ClipN/AN/ABroke ECM clip but connector still latches onto the ECU N/A
99,276
4/29/2019​
ReplaceECMToyota (Junkyard)89961-06G10Swapped OEM ECM with junkyard ECM $ 50.00
99,299
4/30/2019​
MaintenanceECMToyota (Original)89961-06G10Sent to R9K Tuned $ 299.80
99,573
5/11/2019​
99,801
5/18/2019​
ReplaceFront Brake PadWagnerThermoQuiet QC1293Replaced front pads and hardware, warranty replacement N/A
99,801
5/18/2019​
ReplaceRear Brake PadWagnerThermoQuiet QC1212Replaced rear pads and RR hardware, warranty replacement N/A
99,858
5/24/2019​
DynoLate Model Throttle LLCStockN/ADynoed vehicle $ 87.61
99,879
5/24/2019​
InstallRear Window SpoilerSpoiler KingSPK-380RReinstalled spoiler with new 3M VHB and Liquid Nail Fuze It All Surface adhisive N/A
100,113
5/26/2019​
ReplaceECMToyota (Original)89961-06G10Installed tuned Toyota ECM N/A
100,253
6/1/2019​
MaintenanceMass Air Flow SensorDenso22204-31020Cleaned mass air flow sensor N/A
100,253
6/1/2019​
MaintenanceOil ChangeMobil 10W-20 & M1-103AChanged Oil N/A
100,263
6/1/2019​
MaintenanceWindow WiperRainXFusion 24" 19"Replaced wipers N/A
100,353
6/3/2019​
DamageOil CapN/AN/AOil cap leaking oil due to over tightening N/A
100,353
6/3/2019​
ReplaceSpark PlugDensoIK20TTChanged spark plugs to twin-tip type $ 22.16
100,428
6/7/2019​
ReplaceOil CapToyotaPTR04-12108-02Replaced oil cap $ 50.72
6/14/2019​
DynoLate Model Throttle LLCTunedN/ADynoed vehicle $ 87.61
6/25/2019​
101,579
7/3/2019​
ReplaceO2 Sensor B1S2Denso2344260Replaced O2 sensor, had to rethread the hole $ 46.79
7/9/2019​
ReplaceFloor MatHuskyWeatherbeater 98511Installed new (used) floor mats $ 94.45
101,821
7/13/2019​
MaintenanceBrake LubricationPermatexSilicone Ceramic Extreme 24129Lubricated new brake hardware and slide pins N/A
101,821
7/13/2019​
ReplaceFront Caliper Guide PinRaybestosH15240 ProfessionialReplaced front caliper guide pins $ 9.76
101,821
7/13/2019​
ReplaceFront Caliper Guide Pin BushingRaybestosH16153 ProfessionialReplaced front caliper bushings $ 2.97
101,821
7/13/2019​
ReplaceRear Caliper Guide PinWagnerH14160Replaced rear caliper guide pins $ 9.32
101,821
7/13/2019​
ReplaceRear Caliper Guide Pin BushingRaybestosH16094 ProfessionialReplaced rear caliper bushings $ 5.59
101,821
7/13/2019​
ReplaceRear Pad Drag Reduction ClipRaybestosH6033 ProfessionialReplaced rear pad drag reduction clips $ 5.38
7/16/2019​
InformativeLeft Sun VisorN/AN/ALeft sun visor broke N/A
7/19/2019​
ReplaceLeft Sun VisorToyota74320-06780-B0 Replaced sun visor $ 56.79
8/9/2019​
102,912
8/17/2019​
ReplaceFront Brake PadPowerStopZ231293Replaced front pads $ 51.79
102,912
8/17/2019​
ReplaceFront Brake RotorWagnerBD126407EReplaced front rotors, warranty replacement N/A
102,912
8/17/2019​
ReplaceRear Brake PadPowerStopZ231212Replaced rear pads $ 32.99
102,912
8/17/2019​
ReplaceRear Brake RotorWagnerBD126489EReplaced rear rotors, warranty replacement N/A
9/9/2019​
InformativeGrinding noiseN/AN/AGrinding noise from belt area when cold N/A
9/10/2019​
InformativeGrinding noiseN/AN/AGrinding noise seems to be from alternator, noise goes away when warm N/A
193,254
11/2/2019​
11/4/2019​
InformativeOil LeakN/AN/AOil leak seems to be coming from the oil dipstick o-ring N/A
104,827
11/30/2019​
104,827
11/30/2019​
ReplaceInterior LED LightingSUPERBRIGHTLEDs3022, 921, 194, 74Swapped LED cool white to natural white $ 40.55
105,754
1/31/2020​
MaintenanceHingesN/AN/ALubricated body hinges N/A
2/11/2020​
DTCEngine CodeN/AC0210Rear Speed Sensor RH Circuit N/A
2/11/2020​
DTCEngine CodeN/AC0215Rear Speed Sensor LH Circuit N/A
2/12/2020​
DTCEngine CodeN/AB1423Open in Pressure Sensor Circuit / Abnormal Refrigerant Pressure N/A
3/11/2020​
MaintenanceWheel AlignmentFirestoneN/AWheels alighnment, no issues N/A
Total: $ 5,090.06
Plenty you can do.
2/8/2013​
ReplaceFloor MatHuskyWeatherbeater 98512Put in new floor mats$ 123.95
2/8/2013​
ReplaceHigh BeamPhilipsVisionPlus 9005Replaced high beams$ 12.58
2/8/2013​
ReplaceLow BeamPhilipsCrystalVision Ultra H11Replaced low beams$ 29.17
7/9/2013​
InstallEngine RebuildToyotaT-SB-0094-11Toyota rebuilt engine with updated pistons and replaced water pumpN/A
8/10/2013​
ReplaceHigh BeamPhilipsCrystalVision Ultra 9005Replaced high beams$ 9.99
9/6/2013​
InstallFog LightEbayGenericInstalled fog lights$ 39.99
44,960
2/8/2014​
InstallVent Visor (Sides)WeatherTechDark 82421Installed vent visors$ 99.95
45,100
2/14/2014​
InstallTail LightSpyderLEDALT-YD-TCAM07-LED-RCInstalled LED tail light$ 188.95
45,100
2/17/2014​
InstallFog LightiJDMToy3000K LED H11Installed LED fog light$ 80.99
2/21/2014​
ReplaceFog LightDepoFog Light Cover x2Replaced fog light covers$ 18.88
49,210
6/25/2014​
InstallCold Air IntakeK&N69-8610TTKInstalled cold air intake$ 305.50
49,620
7/8/2014​
InstallReverse LightVLEDLED 5000KInstalled LED reverse light$ 36.74
52,028
9/12/2014​
MaintenanceATF Drain & FillToyotaWorld Standard ATFATF drain and fillN/A
56,451
3/16/2015​
InstallLow BeamMorimotoElite 5000K HID H11Installed HID low beam$ 150.00
59,450
5/23/2015​
ReplaceBatteryO'ReillySuper Start 24REXTOEM battery finally diedN/A
64,171
9/20/2015​
ReplaceRear Sway LinkMoogK750011Replaced rear sway linksN/A
74,560
9/27/2016​
InstallWindow TintStereo1One35% TintWindows tinted 35%$ 145.00
10/10/2016​
InstallTow LoopRaceQuip897147Installed tow loop on frong bumper$ 30.94
10/10/2016​
InstallTransport HookToyota51968-33020Installed transport hook$ 44.61
74,339
10/11/2016​
ReplaceCoolantToyotaToyota Super Long LifeBusted radiatorN/A
74,339
10/11/2016​
ReplaceRadiatorProtechN/ABusted radiatorN/A
75,800
11/18/2016​
InstallTires (OEM)BFGoodrichAdvantage T/A SportInstalled tiresN/A
75,980
11/28/2016​
InstallHigh BeamMorimoto2-Stoke LED 9005Installed LED high beam$ 90.00
3/1/2017​
InstallVent Visor (Rear)Spoiler KingSPK-244RInstalled rear vent visor$ 28.49
78,273
3/7/2017​
MaintenanceThrottle BodyN/AN/ACleaned throttle bodyN/A
78,505
3/14/2017​
MaintenanceAir FilterK&NRU-4990Cleaned air filterN/A
78,810
3/27/2017​
InstallStrut BarMegan RacingMR-SB-TCA07FU-1PInstalled strutbar$ 82.98
80,010
4/28/2017​
MaintenanceWindow WiperRainXWeatherbeater 24" 19"Replaced wipersN/A
82,507
8/25/2017​
MaintenanceFuel CleanerTechtronConcentrate PlusAdded fuel cleanerN/A
82,507
8/30/2017​
InstallThrottle ControllerWeapon-R656-112-102Installed throttle controller$ 153.84
82,750
9/4/2017​
MaintenanceOil ChangeMobil 10W-20 & M1-103AOil changeN/A
82,750
9/14/2017​
MaintenanceCabin Air FilterFramCF-10285Replaced cabin air filterN/A
83,712
9/25/2017​
DTCEngine CodeN/AP2121Very low throttle, reset throttle controllerN/A
83,712
9/25/2017​
InstallVent Visor (Rear)EbayGenericInstalled rear vent visor$ 46.89
83,712
9/25/2017​
RepairThrottle ControllerWireGenericSpliced into arm rest 12v connectorN/A
84,569
10/30/2017​
ReplaceDoor Handle CoverToyota69217-06030-B2Old door handle cover was lost, replaced partN/A
11/30/2017​
InformativeFog LightN/AN/AFog lights stopped workingN/A
11/30/2017​
ReplaceLow BeamMorimoto5500K H11B XB HIDReplaced HID bulbs with updated version$ 43.77
12/5/2017​
InformativeFog LightN/AN/AElectrical connector near battery has weak connect, replace the connectorsN/A
87,163
1/15/2018​
InstallMufflerSpeed DaddySDD-CBEMUTCA07Installed new muffler, replaced and welded new muffler tip$ 91.83
2/10/2018​
InformativeBlower MotorN/AN/AMakes sound when on.N/A
2/13/2018​
InformativeBlower MotorN/AN/ASound disappearedN/A
2/21/2018​
InformativeFog LightN/AN/ARight fog light deadN/A
3/17/2018​
RepairPaintN/AN/AUsed Loctite Rust Neutralizer and Jeff's Paint on deep scratches and rust spotsN/A
89,551
3/30/2018​
InstallVent Visor (Rear)LT Sport100000000552-201Installed rear vent visor$ 49.99
89,551
3/30/2018​
InstallVinyl WrapAverySW900-190-0 Gloss BlackVinyl wrapped roof$ 52.00
90,000
4/21/2018​
InstallFloor MatHuskyWeatherBeater 44501Installed cargo mat$ 40.38
90,000
4/21/2018​
90,000
4/21/2018​
ReplaceVinyl WrapAverySW900-190-0 Gloss BlackRemoved vinyl wrap from roofN/A
90,030
4/24/2018​
90,380
4/28/2018​
90,697
5/7/2018​
InstallFog LightMorimotoXB LED (Yell0w Film)Installed new foglight housing$ 185.00
90,697
5/7/2018​
ReplaceLH Fog Lamp CoverMutiple ManufacturersTO2598101Swapped fog lamp cover$ 2.75
90,697
5/7/2018​
ReplaceRH Fog Lamp CoverMutiple ManufacturersTO2599101Swapped fog lamp cover$ 2.75
90,697
5/7/2018​
ReplaceRH Inner Fender Splash ShieldMutiple ManufacturersTO1251122Installed splash shield$ 15.38
92,799
7/6/2018​
ReplaceThrottle ControllerWeapon-R656-112-102Rewired throttle controlllerN/A
92,822
7/10/2018​
MaintenanceTire RotationN/AN/AFront to BackN/A
92,822
7/10/2018​
ReplaceTires (OEM)BFGoodrichAdvantage T/A SportReplaced two tires due to plug leaking, T Rated$ 175.30
7/20/2018​
ReplacePCV ValveToyota12204-28030Replaced PCV valve$ 6.31
93,239
7/30/2018​
ReplaceSpark PlugDensoSK20R11Replaced spark plugs$ 22.44
93,355
8/4/2018​
ReplaceBelt TensionerContinental49396Replaced belt tensioner and swapped 85mm bolt for 70mm or 75mm bolt$ 135.79
93,355
8/4/2018​
ReplaceSerpentine BeltContinental4070752Replaced belt$ 17.08
93,578
8/15/2018​
MaintenanceWheel AlignmentFirestoneN/AWheels alighnment, minor issuesN/A
94,011
8/26/2018​
InstallRear Window SpoilerSpoiler KingSPK-380RInstalled rear window spoiler$ 125.30
94,085
9/5/2018​
DTCEngine CodeN/AP0137O2 Sensor Circuit Low Voltage Bank 1 Sensor 2N/A
94,321
9/17/2018​
ReplaceBelt Moulding Assembly FRToyota75710-33130Vinyl wrapped and replaced belt moulding$ 50.45
94,321
9/17/2018​
ReplaceBelt Moulding Assembly RRToyota75730-33130Vinyl wrapped and replaced belt moulding$ 58.54
94,374
9/21/2018​
ReplaceBelt Moulding Assembly FLToyota75720-33130Vinyl wrapped and replaced belt moulding$ 51.99
94,374
9/21/2018​
ReplaceVent Visor (Sides)WeatherTechDark 82421Front visor warranty replacementN/A
94,014
9/23/2018​
InstallLicense PlateWI DMVADW-5433Installed new license plate after car registration$ 194.50
94,014
9/23/2018​
InstallRear Window SpoilerSpoiler KingSPK-380RReinstalled spoiler with new 3M VHB and Lexel adhisiveN/A
94,044
9/24/2018​
ReplaceBelt Moulding Assembly RLToyota75740-33130Vinyl wrapped and replaced belt moulding$ 37.46
95,222
10/20/2018​
95,479
11/3/2018​
ReplaceFront Speaker AdaptorScoscheSAT69Replaced front speakers$ 7.99
95,479
11/3/2018​
ReplaceFront Speaker ConnectorsCrutchfield12071034LReplaced front speakers$ 9.99
95,479
11/3/2018​
ReplaceFront SpeakersJBLClub 6520Replaced front speakers$ 49.90
95,479
11/3/2018​
ReplaceRear Deck SpeakerJBLClub 9630Replaced rear deck speakers$ 69.95
95,479
11/3/2018​
ReplaceRear Deck Speaker AdaptorCustom Install PartsB007ZREFCAReplaced rear deck speakers$ 15.99
95,479
11/3/2018​
ReplaceRear Deck Speaker ConnectorMetra72-8104Replaced rear deck speakers$ 6.95
96,479
11/20/2018​
ReplaceRadiator CapTRDPTR04-00000-031.1 bar (16 psi) radiator cap replaced by 1.3 bar (19 psi) radiator cap$ 37.44
97,349
1/18/2019​
InstallInterior Footwell LightingSUPERBRIGHTLEDsWFLS-NW30-BK: 50cm[19.7in] Cool WhiteInstalled wiring harness to the dome light and interior LED footwell lighting$ 47.57
98,021
2/24/2019​
ReplaceInterior Footwell LightingSUPERBRIGHTLEDsWFLS-NW30-BK: 50cm[19.7in] Cool WhiteRewired LR interior LED footwell lightingN/A
98,049
2/27/2019​
InformativeTail LightN/AN/ALR Tail light went out, issue caused by lose wiringN/A
98,049
2/27/2019​
InstallRear Deck SpeakersN/AN/APlaced to sheets of foam due to rear deck rattle during heavy bass songs$ 3.84
98,426
3/15/2019​
InstallPocket PodCoverCraftTO1012CHInstalled pocket pod on trunk lid$ 54.78
98,450
3/20/2019​
InformativeATF Oil SealN/AN/ARight oil seal leakingN/A
98,450
3/20/2019​
InformativePower SteeringN/AN/APower steering hose leaking near resoviorN/A
98,450
3/20/2019​
InstallExhaustMegan RacingMR-CBS-TCA07L4Installed exhaust system$ 399.99
98,450
3/20/2019​
MaintenanceATF FluidToyotaWorld Standard ATF5 quarts of Toyota World Standard ATF$ 46.42
98,450
3/20/2019​
MaintenanceATF Pan GasketToyota35168-21020Replaced ATF pan gasket$ 11.42
98,450
3/20/2019​
MaintenanceATF Strainer (Filter)Toyota35330-08010Replaced ATF strainer$ 42.38
98,450
3/20/2019​
MaintenanceATF Strainer SealToyota90080-30077Replaced ATF strainer seal$ 4.71
98,585
3/23/2019​
MaintenanceWindow WiperRainXLatitude 24" 19"Replaced wipersN/A
98,585
3/24/2019​
98,858
4/6/2019​
DamageRR Caliper Slide PinN/AN/ARR caliper slide pin and boot is damaged and needs to be replacedN/A
98,858
4/6/2019​
MaintenanceBrake LubricationPermatexSilicone Ceramic Extreme 24128Lubricated new brake hardware and slide pinsN/A
98,858
4/6/2019​
MaintenanceRear Sway LinkAMSOILSynthetic Multi-Purpose Grease NLGI #2Lubed rear sway linksN/A
98,858
4/6/2019​
ReplaceFront Brake PadWagnerThermoQuiet QC1293Replaced front pads$ 28.89
98,858
4/6/2019​
ReplaceFront Brake RotorWagnerBD126407EReplaced front rotors$ 73.58
98,858
4/6/2019​
ReplaceRear Brake PadWagnerThermoQuiet QC1212Replaced rear pads$ 27.79
98,858
4/6/2019​
ReplaceRear Brake RotorWagnerBD126489EReplaced rear rotors$ 49.58
99,044
4/20/2019​
InformativeBrakesN/AN/ABrake schreeching noiseN/A
99,044
4/20/2019​
99,044
4/20/2019​
99,252
4/27/2019​
MaintenanceBrake Fluid FlushWagnerFC133301 DOT 5.1Flushed brake fluid with Wagner DOT 5.1N/A
99,252
4/27/2019​
ReplaceRear Bottom Rear Caliper PinsWagnerH14160Replace rear bottom caliper pins$ 11.74
99,252
4/27/2019​
ReplaceRight Rear Caliper Pin BootsWagnerH18100Replace caliper pin boots$ 4.43
99,276
4/29/2019​
InformativeECM ClipN/AN/ABroke ECM clip but connector still latches onto the ECUN/A
99,276
4/29/2019​
ReplaceECMToyota (Junkyard)89961-06G10Swapped OEM ECM with junkyard ECM$ 50.00
99,299
4/30/2019​
MaintenanceECMToyota (Original)89961-06G10Sent to R9K Tuned$ 299.80
99,573
5/11/2019​
99,801
5/18/2019​
ReplaceFront Brake PadWagnerThermoQuiet QC1293Replaced front pads and hardware, warranty replacementN/A
99,801
5/18/2019​
ReplaceRear Brake PadWagnerThermoQuiet QC1212Replaced rear pads and RR hardware, warranty replacementN/A
99,858
5/24/2019​
DynoLate Model Throttle LLCStockN/ADynoed vehicle$ 87.61
99,879
5/24/2019​
InstallRear Window SpoilerSpoiler KingSPK-380RReinstalled spoiler with new 3M VHB and Liquid Nail Fuze It All Surface adhisiveN/A
100,113
5/26/2019​
ReplaceECMToyota (Original)89961-06G10Installed tuned Toyota ECMN/A
100,253
6/1/2019​
MaintenanceMass Air Flow SensorDenso22204-31020Cleaned mass air flow sensorN/A
100,253
6/1/2019​
MaintenanceOil ChangeMobil 10W-20 & M1-103AChanged OilN/A
100,263
6/1/2019​
MaintenanceWindow WiperRainXFusion 24" 19"Replaced wipersN/A
100,353
6/3/2019​
DamageOil CapN/AN/AOil cap leaking oil due to over tighteningN/A
100,353
6/3/2019​
ReplaceSpark PlugDensoIK20TTChanged spark plugs to twin-tip type$ 22.16
100,428
6/7/2019​
ReplaceOil CapToyotaPTR04-12108-02Replaced oil cap$ 50.72
6/14/2019​
DynoLate Model Throttle LLCTunedN/ADynoed vehicle$ 87.61
6/25/2019​
101,579
7/3/2019​
ReplaceO2 Sensor B1S2Denso2344260Replaced O2 sensor, had to rethread the hole$ 46.79
7/9/2019​
ReplaceFloor MatHuskyWeatherbeater 98511Installed new (used) floor mats$ 94.45
101,821
7/13/2019​
MaintenanceBrake LubricationPermatexSilicone Ceramic Extreme 24129Lubricated new brake hardware and slide pinsN/A
101,821
7/13/2019​
ReplaceFront Caliper Guide PinRaybestosH15240 ProfessionialReplaced front caliper guide pins$ 9.76
101,821
7/13/2019​
ReplaceFront Caliper Guide Pin BushingRaybestosH16153 ProfessionialReplaced front caliper bushings$ 2.97
101,821
7/13/2019​
ReplaceRear Caliper Guide PinWagnerH14160Replaced rear caliper guide pins$ 9.32
101,821
7/13/2019​
ReplaceRear Caliper Guide Pin BushingRaybestosH16094 ProfessionialReplaced rear caliper bushings$ 5.59
101,821
7/13/2019​
ReplaceRear Pad Drag Reduction ClipRaybestosH6033 ProfessionialReplaced rear pad drag reduction clips$ 5.38
7/16/2019​
InformativeLeft Sun VisorN/AN/ALeft sun visor brokeN/A
7/19/2019​
ReplaceLeft Sun VisorToyota74320-06780-B0Replaced sun visor$ 56.79
8/9/2019​
102,912
8/17/2019​
ReplaceFront Brake PadPowerStopZ231293Replaced front pads$ 51.79
102,912
8/17/2019​
ReplaceFront Brake RotorWagnerBD126407EReplaced front rotors, warranty replacementN/A
102,912
8/17/2019​
ReplaceRear Brake PadPowerStopZ231212Replaced rear pads$ 32.99
102,912
8/17/2019​
ReplaceRear Brake RotorWagnerBD126489EReplaced rear rotors, warranty replacementN/A
9/9/2019​
InformativeGrinding noiseN/AN/AGrinding noise from belt area when coldN/A
9/10/2019​
InformativeGrinding noiseN/AN/AGrinding noise seems to be from alternator, noise goes away when warmN/A
193,254
11/2/2019​
11/4/2019​
InformativeOil LeakN/AN/AOil leak seems to be coming from the oil dipstick o-ringN/A
104,827
11/30/2019​
104,827
11/30/2019​
ReplaceInterior LED LightingSUPERBRIGHTLEDs3022, 921, 194, 74Swapped LED cool white to natural white$ 40.55
105,754
1/31/2020​
MaintenanceHingesN/AN/ALubricated body hingesN/A
2/11/2020​
DTCEngine CodeN/AC0210Rear Speed Sensor RH CircuitN/A
2/11/2020​
DTCEngine CodeN/AC0215Rear Speed Sensor LH CircuitN/A
2/12/2020​
DTCEngine CodeN/AB1423Open in Pressure Sensor Circuit / Abnormal Refrigerant PressureN/A
3/11/2020​
MaintenanceWheel AlignmentFirestoneN/AWheels alighnment, no issuesN/A
Total:$ 5,090.06
Awesome! I appreciate the detail.
Given the age of the car and limited resources (since it doesn't make sense to put in $3k into a car that is worth $3k), can you point out a few essentials?
You got the important bits. Despite the 2AZ being a known oil burner, it really is a low maintenance engine.
  • Serpentine belt
  • Spark plugs
  • PCV valve
  • Oil change
  • Power steering flush
  • Coolant flush
    • Thermostat optional
    • Radiator hoses optional
  • ATF drain-&-fill and filter
  • Brake flush
  • Techron Fuel System Cleaner
  • Serpentine belt
  • Spark plugs
  • PCV valve
  • Oil change
  • Coolant flush
  • Brake flush
Perfect!
Oil change and Techron Fuel System Cleaner is something I am already doing every 5 000 miles.
Looks like the PCV Valve and Serpentine belt as well as the spark plugs are all things that aren't incredibly hard to do. Is this a correct assumption?
All the flush items seem to be something an actual shop is better suited to do.
Perfect!
  • Serpentine belt
    • This "seems" easy but a lot can go wrong. The main thing being that you can easily break the bracket you need to release tension on the tensioner. Not trying to scare you but it happen to me. (it's in my spreadsheet)
  • Spark plugs
    • Less than five minutes
  • PCV valve
  • Oil change
    • This can be a bit easy, just messy
  • Coolant flush
  • Brake flush
    • This can be a bit easy, just gotta get lucky with rust and you need someone to assist you
On that note, I have a set of four Denso Long Life Spark Plugs that are less than a year old and used if you want them. Just gotta pay shipping. They need a home! They are the SR-XXXX spark plugs in my spreadsheet.
2015 4 Runner SR5
Welcome to the site Caf-Flo
A few questions:
How DIY capable are you? Can you do jobs like strut replacement, suspension replacement, etc.?
How valuable is the car to you?
That last question goes to your statement about the car's resell value and money you would put into it. I look at it another way: how much would you spend to get another vehicle. The nice thing about your car is it is very easy to work on, no specialty tools needed. A metric socket set, breaker bar, and you can do a whole lot. In fact, 10mm, 12mm, 14mm is all you need for many jobs. When you get into the suspension you will need 17, 19, 21mm sockets. And then the axle nut socket but that's not expensive. If you are short on tools a trip to Harbor Freight and about $50 will set you up to do most jobs.
Even if it is only "worth" $3k, that would not deter me from putting $3k into it as the alternatives are 1) buy a new car for over $20k (comparable car) or 2) pay for someone else's headache used car that most likely will have some issue or another to deal with; the lower the price the more you will have to deal with in maintenance/repair. The right $3k into your car should give you another decade of reliable operation. The true value of a car is what it provides for you or what someone will pay for it.
I pulled the oil burning engine out of mine (daughter seized it) and replaced it with a rebuilt engine. I swapped the transmission when it went belly up due to an odd issue. I have replaced the entire suspension, this and that due mainly to my daughter destroying it driving wise. So I put more money into it than what a KBB report may say it is worth, but I have an excellent car giving me about 30 mpg that I know every nut and bolt since I did all that work myself. I would not have paid someone to do all that, admittedly.
So, if you can do a lot of the work I'd recommend reading my 2009 Fix 'er up thread and do some of the similar things I talk about. Will last you for a very long time, saving you money in the long run.
Discussion Starter #8
A few questions:
I was reading your reply and thought to myself: "Hmm, I've read a similar thread yesterday where this guy was rebuilding a 2009 Toyota Camry just like yours and it seemed to be a very interesting project", then I recognized it's you!
I saw the 2009 Fix'er upper thread and went through all of what you did to the car, it is really great seeing the dedication you have and what you made out of the car. One reason I am very hesitant about putting too much work into the car is uncertainty about what the upcoming 12 months bring. I'm here on a working visa from Germany and might have to go back, at which point I wouldn't be able to take the car with me (without paying a high premium for shipping and additional modifications to adhere to local regulations) and selling the car then would hurt me twice.
Otherwise I would totally just follow your Fix'er upper thread since the modifications are great and being in the state of Georgia, I wouldn't buy another used or new car since that would just end up giving me another hefty ad valorem tax that I deem rather unnecessary cost.
Other than that I am very much a DIY person and pretty much have all the tools needed for 90% of the tasks outlined.
Given that the car is otherwise in great shape and will probably not do more than 10k miles per year, it seems that I should do the maintenance items outlined by Vangm25 and see to find a garage that would replace the serpentine belt and do a more professional checkup than I can do (just a Software Engineer myself) and do the remaining parts myself.
I just ordered the PCV valve, spark plugs and reading through tutorials to do the different flushes. I'll keep this thread alive while I go at it!
Thanks again!
2015 4 Runner SR5
That make sense. Yeah, you do want to minimize then at least for a year or so if you find out you have a long time to stay. In that case do the simple things and just keep the oil level proper. Loads of folks would buy your car as it is pretty easy to fix that engine, if that is the only thing to deal with. But, they would not pay premium so good plan to hold off on that for now considering your situation.
  • Alignment checked
Don't drain/flush/clean filter in the trannie. I just got my 2009 Camry back from the delaership for an oil points check and asked the same question. The trans is sealed for life. Dealer told me never to touch it. Dealer found the power steering reservoir tubes running behind the engine on the fire wall were leaking, a common problem. Easy to fix but about $300. Check for sure.
I bought my Camry new in Dec 2008 and have 120k miles on it. The belt is till good (amazed by that) as are the hoses. Just check them for sure looking for dry rot. Still on my original alignment - tire treads will give you the clue. Dream car, little maintenance required. Changed my plugs myself using Denso iridiums. Check the gap as 3 of 4 were wrong out of the box. Be very careful in adjusting the gap so not to damage the iridium. Also checked the coils and still okay. Dealer said the coils should last to about 150k. Be certain to change your PCV valve which is cheap and easy to get at. Also clean your MAF wires with the proper spray and clean your TBI plate and connections with its proper spray. There are good vides on You Tube showing how to do all of this. Then it should be running like a clock.
Trans is not sealed for life. Definitely change the ATF fluid, filter, and clean/replace/upgrade the pan magnets. Someone's dealer is an idiot and some have blind faith in bad info from said dealers. And, no automaker has the balls to publicly define a 'lifetime'. From a marketing standpoint, its your loan/lease period.
10yr/100k is a great time to replace the thermostat/radiator cap.... since you're draining all the coolant anyways. Most here wait for a failed head gasket or overheat event before getting a clue concerning simple predictive preventive maintenance.
Replace spark plugs on a cold engine, use quality plugs, and use a torque wrench. Any double platinum, double iridium, iridium platinum, ruthenium platinum... plug should last a long time. If installed/gapped properly, and not knock-offs, ANY brand will work great. Unless your MPG is bad, engine missing,... plugs can last considerably longer. Pause on this until you get all the other services done.
I don't have an alignment 'checked'. It needs to be performed on all 4 wheels. Don't fall for the its all in spec and good to go. You'll probably have typical toyota 'alignment' issues from tired suspension.
PCV... definitely. Most wait until they sludge up or convert their engines into oil burners.
PSF can be siphoned an refilled.... and repeated often. Use a quality synth PSF/ATF.
I might assume that a car that drove 100k miles had enough oil changes, bottles of FI cleaners, air filters, cabin air filters, brake jobs,..... that I will simply leave out 'common enough' stuff and other things, like mods to the vehicle.
I've seen plenty of belts fail so definitely replace the serpentine belt. Pay attention to belt tensioners, idler pulleys, alternator/waterpump/pspump bearings......
Struts/springs/controls arms/balljoints..... suspension in general, replace in pairs as NEEDED or for some performance replacement. I've drove both of my Camries to 160k-200k without suspension rebuilding. Springs replaced for sagging along with struts that were beginning to leak and bounce, balljoints/tierod loose, rubber control arm bushings biodegraded..... keep driving until you notice handling issues and repair/upgrade as needed.
There are lots of sealed transmissions these days, and since the primary breakdown in ATF is generally caused by oxidation, sealed transmissions have eliminated virtually all of it.
You can always take off a transmission pan and do a fluid change. I don't. I have vehicles with non-sealed transmissions, several of which are trucks that have been workhorses, that are over 200K, one approaching 300K, in which I've never done an ATF change. The 1999 Jag I owned had a sealed transmission and was around 150K when I sold it to a friend, sans ATF change.
No matter how technology (and fluid technology is included there) changes there will always be many holdovers who want to do it "like daddy and granddaddy did" for decades after that's been ill-advised and unnecessary.
Given that I simply don't do transmission fluid changes, and have had multiple vehicles go hundreds of thousands of miles without issue, I continue to say, "If it ain't broke, or showing signs of something being wrong, don't fix it." That extends to ATF changes.
1 - 12 of 12 Posts
