1 - 4 of 4 Posts
I need to install a inline converter but i don't know which color wire is right speaker output or left speaker output. and also i'm not sure which ones are remote wires. anyone have answer for me? or a diagram that tells me which is which?
· The random one
2010 Corolla CE
there's no remote on OEM stereo, take it out of the Accessory/radio power GREY for the REM, check it up with a voltmeter that its only +12v when key is on, and off when key off. for the line converter I soldered wires to the back speaker inside the trunk to minimize impact on OEM wiring. all is tucked inside the trunk cover. There's plenty of threads, use the search function, if you will only power an amplifier in mono (subs) you dont need all four speakers.
09 corolla
Battery LIGHT BLUE (+) RADIO HARNESS
Accesory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Power Antenna TAN (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) VIOLET
RF Speaker (+) LIGHT GREEN
RF Speaker (-) BLUE
LR Speaker (+) BLACK
LR Speaker (-) YELLOW
RR Speaker (+) RED
RR Speaker (-) WHITE
Speed Sense VIOLET (AC) AT Radio harness
Reverse Lights RED (+) VEHICLE FUSEBOX
· Crazy Software Developer
09 corolla
LF Speaker (+) PINK
RF Speaker (-) BLUE
RR Speaker (+) RED
These would be about the same for the 2010 corolla too right?
Gotta put together a harness tomorrow.
Never mind, connected my new harness and everything seems to be wired to the same as stated above.
1 - 4 of 4 Posts
