1 - 6 of 6 Posts
Discussion Starter · #3 ·
ok let me ask it a better way...the rubber roof mouldings on my 2009 matrix have deteriorated from sun and weathering, anyone know where to get replacement parts other than the obvious "cost-you-an-arm-and-a-leg" online Toyota dealerships? I'd rather not spend $250+ for what would otherwise be a $20 section of rubber weatherstripping...has anyone used anything else with success?
· Administrator
マズダスピード3
You can try rockauto or other online Toyota retailers. Is it just cosmetic the reason for replacing? Or is there a water leak. It is a gamble if you try to source one from a junkyard.
I do believe the previous link I posted contains various solutions for reasonable cost.
However, a roll of BLUE PAINTERS TAPE & a CAN OF FLEX SEAL spray will set ya back 20 bux........that's what us HILLBILLIES OUT IN THE STIX would do.
Up until you could get this newfangled FLEX SEAL.....used to be BALING WIRE & BUBBLE GUM
1 - 6 of 6 Posts
