1 - 20 of 31 Posts
Hello everybody!
For the past few weeks I have been having issues with my Corolla. She starts hard wether being hot or cold, and she will stall when coming to an almost complete stop. I usually have to switch her in neutral before I come to a stop.
Now my father and I have come up with a few different scenarios of what could be the issues, but we have either replaced or checked them. This is everything we have done to her so far:
  • replaced Camshaft position sensors (both)
  • replaced VVT-i Oil control valve filter
  • checked VVT-i solenoids (both)
  • spark plugs and coils replaced feb. of this year
  • battery replaced march of this year
None of the above has made a difference. Was wondering if you all had any ideas.
Oh and she's got about 300,000ish miles on her. The engine runs good under acceleration, but gives off a gurgling noise thats difficult to describe.
05 camry 07 tacoma
You have a scanner that can read live data?
In the meantime has throttle body been cleaned?
05 camry 07 tacoma
Important when clean TB that both sides of valve and throat shiny clean.
Take EGR apart and at least clean, or replace. I guarantee, at that mileage, it's full of crud. Also, clean all plumbing it is connected to. From that on, run Seafoam through tank once a year. Be happy.
Discussion Starter #11
Could you tell me where the EGR could possibly be located. I haven't been able to find any diagrams/videos on line showing where it could be yet.
My bad. You do not have EGR. Still, something is choking your engine. Symptoms are EGR like, so whatever Toyota designed as EGR substitute for your year/engine, does that.
Discussion Starter #13
No worries. I've been reading up on the PCV valve and have a feeling that it could possibly be it. Currently looking at where it is located on the vehicle. Thank you for the help!
My 2009 Corolla XLE was doing the same thing and I did all kinds of stuff. I wound up replacing the PCV valve and it helped but did not stop the rough idle completely. Now it will about 90% of the time be okay at a stop light or sign, but every once in awhile it still acts up. I have resorted to just going into neutral for the stop duration. When hot and I put it in reverse or drive for a few seconds it will idle down to about 400 RPM and shutter really bad. As soon as I get it to move it is fine. Also my gas mileage has gone down to about 20 MPG. When I first bought the car the gas pedal was extremely sensitive, meaning just a little touch and it was shooting out of the hole like a rocket!! Now I have to go about 1/2 way to the floor to get it to get going. Transmission up shifts and down shifts just fine. Car has 165K miles and I am the original owner. Any Thoughts out there?
I have done the following for sure. Cleaned throttle body, replaced PCV valve, new air filter, cleaned MAF sensor, new plugs and wires, new battery, rebuilt alternator, I am sure I am forgetting a few things but this car is costing way too much so I just stopped throwing money at it. I have thought of taking it to Toyota and letting they charge me $200 to diagnose it and if I elect to let them repair it, then that money goes towards the repairs.
Discussion Starter #18
My father and I are going to replace the PCV valve tonight. However, I did bring it to the repair shop and they took a look at it but couldn't figure out the problem. They had everything disconnected until Monday when I went to go pick it up. It ran fine Monday, Tuesday, and part of Wednesday. This got me thinking could it be a faulty sensor? If it were something mechanical wouldn't it show up right away after everything was hooked back up when I got my car back on Monday?
09 Corolla Base
If they disconnected and reconnected everything I'm thinking it's possible there was a dirty/corroded connection and somewhere in the process that 'cleaned' up the connection.
I forgot to mention all Parts used on my Corolla are Toyota and Denso. I learned my lesson with non Toyota parts the hard way. a long time ago. Also when I put in the new Toyota PCV valve, the old one was still rattling, so it was good but put new one in anyway, as it was a $15 part. I am in the greater Houston, Tx. area and we are hot for about 8.5 months of the year. Today it hit 92 outside, but it is 74 in my house!!
1 - 20 of 31 Posts
