1 - 7 of 7 Posts
Hello All. My 2009 Venza blower motor will not work at any speed. I suppose it could be the motor itself, but where is the fuse located to try that first? All i see is a relay under the hood in the fuse box. Thanks for your help
Curious if you got yours running... I have replaced my relay AND the complete blower motor.. still NOTHING... next guess is the resistor.. but honestly not sure where that is located and I need HELP! Suggestions ??
I don't believe there a resistor, that's old tech. I suspect the blower circuit uses a pcm encoder as did my '03 4runner.
1 - 7 of 7 Posts
