1 - 3 of 3 Posts
My TRD 4X4 has 121k miles on it and recently the fan motor would only work on the highest setting.
I replaced it with this motor: TYC 700188 Fan Motor Assembly
It worked on Speed 1, Speed 2 then Speed 3 was almost Speed 1 level and High Speed worked fine.
At times only the highest setting works.
I ordered a replacement and have the same issue. Speeds 1, 2 and 4 work properly but 3rd speed is very low.
What else can I check?
Thanks in advance!
WFR
Problem probably not in the fan motor. "High speed only" symptom is almost always the resistor going bad. There are threads here on replacing it...do a search.
Thanks so much!
Just ordered the resistor kit.
May put the OE fan back in after changing it out.
1 - 3 of 3 Posts
