I have a 2011 base model Camry.
The passenger side front door lock (electronic) stopped working a while back.
I fixed the drivers side issue when replacing the speakers in the car (driver side would stick and sometime not move by hand).
What is the best way to determine if the door lock actuator is dead or something else is wrong?
Here is what I know at this moment.
1) Key from the outside will unlock the door (and all the other doors)
2) using the electronic locks from any door (fronts) does not lock the passenger door, nor unlock it
3) If manually locking/unlocking the door, there is no binding or struggle to move the lock.
4) the door does unlock with the door handle (I am assuming this is a manual item)
Is there a DYI on this (I looked and found nothing)?
Do I have to replace the entire actuator piece (looked and saw they are near $250)?
Thanks,
Terry
Thanks,
Terry
