1 - 3 of 3 Posts
Hi I’m new here, my toyota camry i just bought 6 months ago with 250k
The seller told me that the hybrid Battery Pack is bad , but he said whenever the warning lights come on just plug a generic obd2 scanner he supplied and clear the codes
I was doing this for a while , the car drives normal with lower 30s mpg untill last week the warnig lights will come on followed by loss of power and the car stalls , and after i clear the code it does it again in feww minutes
My question is : does a bad hybrid battery cause the camry to stall ?
I’m sure the hybrid battery is bad But is this what causing the stall or not ?
I don’t want to spend 1500$ on a rebuild battery to discover that there’s a different issues with the car
Hi i found a cure from a very expert person on hybrid cars
What i had was code p3190
And code p0A080
Symptoms are : chs warning light shortly after all lights on and los of power
The amswer to this particular condition is replacing the Fuse box Relay controle Module that wont fix the battery but the car won’t stall any more
1 - 3 of 3 Posts
