Hi All,
I’ve been searching online and on the forums but i cant seen to find any info on sequoia soft brakes. I found a lot of info about tundras so i decided to post on here and see if u guys can help. I have a 2011 sequoia sr5. Just recently, i’ve experience soft brakes meaning to stop the car, i would have to step on the brakes all the way to the floor which is not normal. I did some test for the brake booster, master cylinder, check the brake lines and found nothing. One thing that i do noticed is that the clunking noise is no longer there. Im not sure if you guys are familiar with the clunking noise but my sequoia at first startup usually makes a clunk noise once i reach 12mph to 15mph. According to the tundra owners, the clunking noise is a ABS self check. I bought my sequoia with 42k miles and now im at 107k. I used to hear the clunking every morning but now, im no longer hearing it and my brakes are now soft makes me believe that its the ABS actuator that needs to be replace. Anyone experience any soft braking issues? If so, have u fix it?
