2012 Camry SE - Left Headlight not working
938 views 3 replies 3 participants last post by  KToyota
So my low beam went out and I figured it was just the bulb. Replaced with a new and still didn't work; checked fuses and they're good. I swapped bulbs (Left to right) and the left still doesn't work (bur worked on the right side.) Swapped fuses (25 and 26) and Left still doesn't work. Anyone have this issue before? No damage, modifications, obvious signs of corrosion, and the wire and wrapping does not have any visible damage. Tried a search and after scanning 180 threads didn't see a similar issue. Thank you in advance!
Check ground wires. They. Get corroded/rusted.
Look for a group at each fender into one screw. White with BLK stripe.
Clean and replace using dielectric silicon or just some hair spray from a SPRAY can.
Sent from my PH-1 using Tapatalk
Reactions: KToyota
Likely socket itself or fusible link somewhere.
If light works when directly supplied from battery:
Don't bother with extensive repairs. Run jump wire from the working light. Iffing Mitsubishes had socket issues so I simply did that on son's Eclipse and it all worked fine for couple years. Use those small squeeze onto wire splicing boxes. they are great.
