1 - 5 of 5 Posts
Hi everyone
Please see picture below (front passenger side under carpet). Seems like there is possibly a pinhole leak either on the hose side or white plastic. Leaking where I've circled. Should I replace both? Or do you think a zip tie will help? Leaks slow while air condition is running. Thanks for your help!
305920
Slow AF
2012 Matrix
The second part of the black hose that exits the car might be plugged and that's causing it to leak that way. Deffs check that as well.
And for the hole, you could probably just put a dab of silicone on it to seal the hole. Don't seal around where it comes apart though.
I took the 1st hose from the centre console out, along with the white plastic piece and the hose that comes out of the other end of the white plastic. Not plugged. Where I circled gets wet after time when the AC is running this is why I thought maybe it's a pin hole... Other connection points are dry. I guess I could see about ordering a new hose and plastic white piece or try a junk yard... Should I try a zip tie?
1 - 5 of 5 Posts
