1 - 18 of 18 Posts
2015 Camry XLE V6
Meh... looks like just the light bars are LED - Low & High beams are halogen.
· Photojournalist
2012 Camry LE
why would they flash on and off with turn signal?
Watch some of the newer cars. The law (doesn't apply if HLs are used as DRL) is if the led DRL is within 6 (???) inches of turn signal, that side has to go off when turn signal is on. Some have that side off; other alternate with it. I guess they think it would overpower the amber.
Of course, WHY DRL don't go off when headlights are on is beyond me.
Sent from my STH100-1 using Tapatalk
Odds are output of the headlight would be worse than the oem headlight (which is actually pretty good). And the led strip would be useless during the day. My opinion is it's just a waste of money.
Those were pretty much my concerns, hence wanting feedback from someone that has installed them. I guess I'll hold tight to see if anyone else on TN takes the plung.
Sent from my H1611 using Tapatalk
Does anyone have any recommendations to stop the DRL from flickering of newly installed Lasfit LA Plus Series 9005 9-16V led bulbs? Lasfit sent me a LED intelligent decoder, which worked temporarily, but kept shutting off because the attachment points were too loose, even after taped together tightly.
2013 Camry XLE
Better installation.
Just simply don't use LED for the high beam/DRL and just stick with halogen? Not worth the hassle.
2013 Camry XLE
Actually this really says it all doesn't it? Not installed very well. Solder and shrink tube, is the way to go. Not twist and tape.
1 - 18 of 18 Posts
