Hi everyone,
1st time post and been on this forum for the past year or so since I bought my 2015 Corolla S Dec last year (12/31/22) and found a lot of helpful info so far so thanks to all.
Quick info:
Previously owned (Carmax)
Purchased with 86K Miles/Currently at 96K
2-3 previous owners
Very good shape/regularly maintained
So, I have been driving manual for years now. My last car was a Nissan Versa 6 Speed and am very familiar with driving stick overall.
However, once I got the car, I found that (obviously) it was a different machine to get used to driving but but I found that the throttle is VERY sensitive, making shifting into 1st to be very tricky and it took me quite a while to get a smooth consistent shift. Other gears were fine. I just want to know from other owners with the MT, if this is something to be considered normal across all of them and it's not just something weird happening with mine, regarding the clutch behavior described below.
Adding to the fact that the clutch does, what I believe, is something I never noticed other MT do.
The clutch when fully engaged and in 1st gear, when letting off the clutch about half an inch or so, the car pushes forward as it was hitting the bite point. The actual bite point is about a third of the way down and easy to find/get used to. I only downshift when necessary, rev matching every time. Again, I'm just wondering if this is considered 'normal' in these.
At the moment the car is having problems getting into 1st without, what feels like, transmission slip. Stuttering and bumping at the bite point, which just started happening very quickly. Started last week and got very noticeable very fast. I will be getting a transmission fluid change soon as it is around the time it's due anyway, but I would like to know if this is something anyone else has experienced at any point. And more importantly, how everyone else is driving the car. How long you are releasing the clutch for, slowly or semi quickly? Everything about the car from day one felt like, in order to shift smoothly, I HAVE to release the clutch so slow that I am afraid that I am doing it incorrectly and causing unnecessary wear. Any insight would be much appreciated.
TL;DR: How are you all driving, engaging the clutch and shifting? Any weirdness or drastic changes to your driving style you don't feel is normal?
Thanks in advance, all!
Quick info:
2-3 previous owners
