To solve this issue, it would be good to know how the TG works. My GUESS.
Since one can set the opening height, I would assume there is a motor revolution sensor or timer in the ECU to tell it how far to open it - maybe also to close it.
The glove box switch, then, must cut power to the TG ECU, otherwise it wouldn't reset it.
So, the question is, what sensors does the TG ECU use for this?
Since the motors work, it either those sensors, the connections, or the ECU.
The most likely would be a bad/corroded connector.
Anyone got a schematic showing those sensors, wires and ECU location?
