1 - 20 of 34 Posts
Looking at adding a hitch to my 2015 Venza LE with 2.7 L engine, so that I can add a cargo rack to carry a cooler and other gear. But on cars.com it says for 2015 Venza LE 2.7 L FWD:
Dead Weight Hitch - Max Tongue Wt.100 lbs
Most gear racks weigh 50-75 pounds, so not leaving much for gear. Has anyone added a tow hitch and cargo carrier, and if so how much did you carry on it? Certainly do not want to see hitch and cargo rack sliding down road in my rear view mirror!
Discussion Starter · #2 ·
Seeing the 100 lb tongue weight at other websites too. Could get lightest cargo rack, they are 30-40 lbs, and have 60-70 pounds left, that would be okay, but no big cooler filled with ice and food. Other option is to go to a roof rack, but that is not practical for a cooler!
· just a nobody
Echo
2009 Venza V6 AWD
Disclaimer: I'm not experienced in towing or hitch accessories, so do your own due diligence.
I think the tongue weight rating on cars.com comes from the guideline of having 10% (officially 9-11% according to the manual) of the gross trailer weight on the hitch. Venzas without the tow package have a max tow rating of 1000 lbs, that's where the 100 lbs comes from, I'm guessing. With the tow package, the 4 cylinder has a 2500 lbs tow rating.
On the V6 with the tow package and 3500 lbs tow rating, the tongue weight recommendation is a max 350 lbs on cars.com.
I don't know if there's any structural difference between the 4 cylinder and V6 models at the hitch mounting locations.
I suggest checking your vehicle owner's manual, but at least in mine, there's no mention of a max tongue load. The only mention is that the gross vehicle weight rating (GVWR) is the max gross vehicle weight, including occupants, cargo, any optional equipment, as well as the tongue load.
If you find that there is no structural difference between the 4 cylinder and V6 models, then I would think the main figure to keep in mind is not to exceed the GVWR.
Discussion Starter · #7 ·
Yeah, thank you zaza! Will look into it, doubt they made a different frame for same Venza with tow package. etrailers support may know too, will check with them.
2009 Venza V6 AWD
NEO, the tongue weight is specified by the vehicle. Of course the hitch mount has a rated tongue weight too, but that is not the vehicle rated tongue weight.
I think their point is that there isn't a vehicle tongue weight rating, at least as far as I'm aware. The tongue weight matters when towing, according to the gross trailer weight. If you're not towing, then it's just the GVWR that you need to keep in mind. Aside from the hitch's/rack's weight rating, obviously.
Discussion Starter · #12 ·
Yeah, never had a tow hitch with a cargo carrier before, but what you both are saying makes sense. Talked with etrailer.com, they said talk with dealer, will do that tomorrow and get back.
Discussion Starter · #14 ·
I have the class 3 Curt hitch and it has a 350lb tongue weight capacity..I pull a 2500 lb trailer and the tongue weight with it is 250 lbs..works great!
Good to hear, do you know if there are any reinforcements made to the frame where the hitch mounts? Just wondering if my Venza with 2.7 L engine and no tow package has same frame as yours.
2016 Limited V6 -Cosmic grey mica-Black leather
I think the frame is standard...the hitch attached with 6 bolts... relatively easy install with two people....I bought mine from Amazon... recommend this hitch!
Cheers!
Discussion Starter · #16 ·
Cheers!
You would think the frame would be standard, but will find out tomorrow. Etrailer.com has a made in USA hitch with 2" receiver for $190, hard to beat. It also uses 6 bolts to attach to the frame.
Discussion Starter · #18 ·
Just got off the phone with the service manager for my local Toyota dealership, like several of you have pointed out, it is the hitch and cargo carrier that defines the weight limit! So a class III hitch is rated to 350 lbs and cargo carriers are rated to 300-500 lbs. I have about 150 lbs of gear including cooler that I want to put on the 60 lb cargo carrier, at ~210 lb will be well under the rated tongue weight for the hitch.
Thanks for all the feedback and advice!
1 - 20 of 34 Posts
