When the Nav screen is up and running, I select Options, then Map Information and select Speed Limit and the yellow vertical bar is highlighted to the left of the Speed Limit selection I don't see the speed limit showing on the Nav screen as I drive around. Has anyone successfully got the speed limit to show on their Nav screen?
Where on the Nav screen should you see the speed limit?
