1 - 6 of 6 Posts
2018 Camry SE Hybrid - 16,000+ miles on odometer.
I have twice had issues now in refueling our 2018 Camry SE Hybrid, when the fuel tank is low.
The first time, I started refueling, slowly and "manually", as New York State does not allow auto-fill nozzles at gas stations. After about 2.8-gallons was pumped in, the pumps stopped like the tank was full. Knowing the tank was nearly completely empty, since I had driven nearly 580 miles on the tank prior to refilling, with the gas idiot light on and needle pointing directly to 'E'.
I attempted to pump more in, but the car accepted some fuel, then literally "spit it back out" down the side of the car. It didn't just act like I "overfilled" it. It was actually pushing the gasoline back up the fill tube and out!
That day, the car was hot having just been on a three hour drive, and it was very hot outside - 90+ degrees. I then drove around the parking lot several times, and tried to add more fuel, but the Camry would not accept any more gasoline. As I left the station, the gauge was below 1/4 full mark. The next morning, I tried to fill it again, and it accepted around 9 more gallons without an issue.
Today, I pulled in to refuel just as the "gas" light popped on. It was first thing in the morning, 67 degrees outside, and the Camry had been driven just 5 miles from sitting overnight. I could not pump more than 2.2 gallons into the tank! I even waited a minute or so, and tried to continue my fill up, but it just would not accept any more gas.
Later in the morning, after driving only about 30 miles, I stopped again, and was able to pump 8+ gallons in without any issue. AND, I was at the exact same pump as earlier in the morning, thus eliminating a 'pump' causing the problem.
Is anyone else experiencing this problem? I know it's not recommended to operate any vehicle until nearly empty, but what would be causing not being able to refuel, when the tank is empty?
Yes. I've had my car for a year and a half and it's happened twice too. It happened to my old car too to the point where it wouldn't take gas anymore. I dont fill my tank up past the click. In my old car I had the whole tank replaced and that didnt work. I hope someone here had an answer
There's LONG thread on this in RAV4 Hybrid section too. I am suspicious, RAV and Camry have same tank set up. YOu are not alone. Not helpful, but, at least the word is going to dealers and up the ladder.
I have had thus problem when the fueling area was not level... Nose down. Pulled around so that the nose was up (or went down the street to a station where the fueling area was level) and had no problem.
First time this happened I was on the road visiting a relative so I took it to the local dealer. They changed a bunch of parts. All was OK until 6 months later when I stopped at the same gas station and the exact same thing happened again! I went to another station with a level pumping area and had no problem.
Yes sir I have a 2019 had the problem took it to the dealer twice.
the second time the mechanic told me thatit is a feature to luck thehole. You may not touch the little buttom at the side of the little door when pomping Gad . Make sure the nuzzle that has that round lid do not touch that little button with the nuzzle.
1 - 6 of 6 Posts
