Short trips kill battery
Extremely hot or cold weather will torment a battery
Cheap batteries don't last long
So, after you test the alternator/battery volatage at idle and at rpm voltage, have the alternator tested at your local autopart store.
If you're a short tripper, use a trickle charger.
If car sits for more than a couple days, use a trickle charger.
If you don't have outside power for a trickle charger, or a garage with power, use a solar trickle charger.
Make sure battery is spec'd for your weather. They have different northern(cold) and southern(hot) climate batteries.
When you shut the vehicle off, make sure you turn off all non-essentials, including automatic headlights, stereo, interior lights..... PRIOR to shutting off vehicle.
Shop can also measure the draw on the battery when vehicle is off. If excessive, it can be fuse/relay traced, 1 at a time, until you find the fuse/relay/circuit that is drawing excessive power.
And above all, USE A QUALITY BRAND UPSCALE(GOLD/PLATINUM/UNOBTAINIUM/) BATTERY that has a very recent manufacturing/sales date sticker. I find that many lower volume areas have no problem installing 1-2 year old stock battery and 2-6 year old tires. So, DIY the battery if you have to.
