1 - 10 of 10 Posts
I have 2018 toyota Highlander, if the Transmission wasn't shift very well.and i try to scan it.. this the result ( Input/Turbine speed sensor "A" circuit short to Ground or open. Pls what can he be the faulty.
Regardless which forum, the description looks to be a general one that applies to most late model vehicles with Automatic Transmission. Do you have the OBD trouble code? If it is P0715, it indicates signal error between your HL's Engine Control Unit and the Transmission Control Module. Being a 2018 model, still under warranty, I would bring the HL directly to your local Toyota dealer and have the issue resolved. Good Luck!
Edit: correction on the OBD-II code (from P0175 to P0715). Sorry!
Would you kindly let us know what was the verdic and what was done to fix the issue? Thanks!
1 - 10 of 10 Posts
