Hello, I'm new to the site and have a 2 questions about the headlights on my 2019 Highlander Limited Platinum.
1) The low beam headlights seem very dim. At times it's hard to tell if they are on even though the icon is lit on the dashboard (I've checked and they are on). I have to use the fog lights with them in order to see. I had the dealer check them & said they are working as designed.
I went to an auto parts store, after Toyota told me there are no brighter bulbs available, & they suggested the next level up H11 bulb.
I installed the new bulbs but don't see any difference.
Is anyone else having this issue &/or are there any suggestions on what type of bulb would you suggest?
2) The gray cover that covers the low beam headlight access fell off. It dropped somewhere into the car frame. It did not fall to the ground. Does anyone know how important this cover is and has Toyota given it some type of name that I can use to replace it.
Thanks for your help!
