What are your OE tires?26,000 so far. I will probably change them at 30k... 14-15 months of ownership, $700 for a set of tires...That works out to almost $50 a month for tires
Sure you can. But the compound with be hard as a rock. That's why they're guaranteed for 70K. There is no getting around ANY of this. High mileage tires = hard compound. Great handling tires = soft compound. It really is just that simple. The low profile tire equates to much better handling due to it's soft compound. The low profile of the tire ALSO adds to it's curb appeal, along with some added handling benefits. It's why Formula 1 is going to much lower profile tires next year. They're already soft as chewing gum.The Toyota factory tires don't have good UTQG wear ratings to begin with. No, it's not the low profile tires causing it You can get longer wearing tires for the car, like the Continental PureContact LS for it with a 70,000 mile pro-rated warranty on it.
You may or may not get 70K depending on driving habits and roads in your area. You wont see 70K unless you drive like a granny on smooth asphalt roads. I had a 60K rated set of Michelin Primacy - in TX heat on concrete roads it lasted 25K miles. Also most manufacturers including Michelin and Continental use "variable compound" technology: the softer upper layer of rubber to make you go "WOW" my new tires are fri...g quiet and hold the road like nothing before, but as soon as your tires are worn down to the harder layer that should prolong tires life the traction and comfort goes south.The Toyota factory tires don't have good UTQG wear ratings to begin with.
No, it's not the low profile tires causing it.
Bridgestone TuranzaWhat are your OE tires?
That's why it's Pro-rated. The sooner it wears out, the less money you kick out to buy a replacement tire.You may or may not get 70K depending on driving habits and roads in your area. You wont see 70K unless you drive like a granny on smooth asphalt roads. I had a 60K rated set of Michelin Primacy - in TX heat on concrete roads it lasted 25K miles. Also most manufacturers including Michelin and Continental use "variable compound" technology: the softer upper layer of rubber to make you go "WOW" my new tires are fri...g quiet and hold the road like nothing before, but as soon as your tires are worn down to the harder layer that should prolong tires life the traction and comfort goes south.
Tires are a complex engineering product. It's more than just "hardness" of a compound that makes a tire handle better. You have tread design features as well as construction of the tire internals that contribute to handling of a tire.Sure you can. But the compound with be hard as a rock. That's why they're guaranteed for 70K. There is no getting around ANY of this. High mileage tires = hard compound. Great handling tires = soft compound. It really is just that simple. The low profile tire equates to much better handling due to it's soft compound. The low profile of the tire ALSO adds to it's curb appeal, along with some added handling benefits. It's why Formula 1 is going to much lower profile tires next year. They're already soft as chewing gum.
Yeah, you can jack around with tire pressures and the like. But it won't amount to much. You can also add to this the fact that most people who buy high mileage, hard compound tires drive easy. They're not concerned about high performance handling. They want their tires to last as long as possible. While most who buy the high performance, soft compound, low profile tires, drive them harder, and are not all that concerned about how long they'll last. All which adds to the spread in mileage of both.
the person asking about tire life specifically states he has a higher trimmed Camry with a V6 in the title, so apologies for offering recommendations for it and if you think we are all secretly F1 race car driversThose of us who don't try to compete in F1 racing would prefer a "standard profile" tire (whatever that is nowadays) that rides, wears, and handles decently and doesn't cost an arm and a leg. I have an LE, so I'm sure my tires will be a little cheaper than some of the quotes above (but not by much, I'm afraid). Tires have gotten ridiculously expensive, and part of that is the car manufacturers pushing lower profile and higher performance tires. Most people don't need tires for a race car - and I'm not willing to pay for them. I passed on an SE due to its low profile tires. I might have pulled the trigger if it had been shod with the same tires as my LE.
Does your road sucks? Cuz I got 41k miles on the Turanza EL440s with 5/32nds remaining. Never balanced it only rotated every 8-10k milesBridgestone Turanza
Some Camry buyers are looking for reliability with less of the mushball handling most Japanese sedans feature. C/D got .94g with the TRD,. While not a great number, it a cheap car so you can’t expect the world.That's why it's Pro-rated. The sooner it wears out, the less money you kick out to buy a replacement tire.
The UTQG Government approved test track is in West Texas, so manufacturers test on hot texas weather. But, like anything on a car, YMMV, which is why they have the pro-rated warranty.
Soft compound doesn't necessarily = great handling tires. In one extreme, winter tires have a soft compound, but due to the squirmy tread design, using it in the summer does not equal great handling, more like squirmy, less predictable handling.
The summer tires that came optional on the Prius and the FRS, The Michelin Primacy HP, yes, it's a soft summer tire, but its design makes it a rather poor handling tire, I'm willing to bet the All-season Pilot A/S 3 (with a harder compound) handles better than it, and no where near as good as a PSS or PS4S.
A Camry, no matter how much visual rice boy appeal Toyota adds, isn't a sports sedan, it's never going to handle like say a 5-series BMW. Even the new IS still can't compete with the germans when it comes to handling, despite Lexus marketing. Japanese mainstream approach to sportiness is .... "It has a large wheels... rides rough, so it must be sporty"
