I looked at both the printed manual and the PDF online and there’s nothing there. I did take out the cover and I can make out some of the names but not all of them.It's in the owners manual which are free online but should be with the car along with the layout being on the box cover!
If you just want it on when the engine is started, use just the ACC fuse. If your camera supports parking mode then use the ACC fuse for one wire and the DOME fuse for the parking mode wire.Does anyone have a file that shows the cabin's fuse box layout. Im trying to hardwire a dash cam and I want to wire it through the fuse box. The link on I found here doesn't work.
I see the ACC fuse but I don't see the DOME fuse. would it be the same one under panel or no? I do plan on using parking mode on my camera. Its the reason I want to hard wire it. I did get a circuit tester to test which circuits are still live when the car is off. But I want to make sure I don't tap into a fuse for something important like the airbags.If you just want it on when the engine is started, use just the ACC fuse. If your camera supports parking mode then use the ACC fuse for one wire and the DOME fuse for the parking mode wire.
The layout is on the the other side of the fuse cover. If you want to know what each fuse is then go here, Master List of DIY/Tutorials, Lighting/HIDs/LEDs, Fuse...
and under MISC. you'll find the fuse list.
I'll have to double check when I try to install my camera. thank you for the pictures though! what amp fuses did you use for the fuse tap? would it be the same amperage as the ones you tapped into?hmm.. is it different for the 2020 model year? These are the two fuses i used for my dashcam. Its the instrument/cabin fuse panel. Also i took a picture of the fuse box.
View attachment 309495 View attachment 309496
What dash cam do you have installed?they are 15a fuses. they came with the fuse taps.
Nice, I just got a Blackvue DR750-2ch LTEviofo a119 v3
Just curious. At that price, why not just get the aftermarket rearview mirror with cameras on the front and back?viofo a119 v3
never liked those rear view mirror camera's. Though i never used one before, to me they look like they won't be reliable. maybe they are good and will last a long time but ehh.. just don't care for it.Just curious. At that price, why not just get the aftermarket rearview mirror with cameras on the front and back?
CAMERA
Like this :
Yea, I am looking to get one, however, not sure of the qualitynever liked those rear view mirror camera's. Though i never used one before, to me they look like they won't be reliable. maybe they are good and will last a long time but ehh.. just don't care for it.
Wouldn't it not be better to hook up the SFT Lock-ACC for the ACC wire that only gets power when the key is turned?hmm.. is it different for the 2020 model year? These are the two fuses i used for my dashcam. Its the instrument/cabin fuse panel. Also i took a picture of the fuse box.
What page? I don't see it, not even on the index in the back of the manualIt's in the owners manual which are free online but should be with the car along with the layout being on the box cover!
