1 - 7 of 7 Posts
· Administrator
マズダスピード3
Are you still under warranty?
What have you done to try to isolate the noise?
Discussion Starter · #3 ·
Checked sway bar, moved wheel side to side, up and down, checked tie rod. Removed tire to check for something lose. All checks ok. Dealer said warranty is expired. Calling Toyota Corporate in the morning.
· Administrator
マズダスピード3
Is the bump smooth or does it have a high point? Does it occur when you go around 3-5 mph over the speed bump? Noise present if you crawl over the speed bump?
1 - 7 of 7 Posts
