1 - 17 of 17 Posts
2019 Sequoia TRD
Try
PT363-0C200-WT but change the WT from white to BL or whatever color you need. Seems white is WT, maybe BK for black. Remember if you change from chrome you have do to the lower grille and the fog light surrounds to totally black out.
thanks for the info.
I cannot find an image to match this part number anywhere.
Will Toyota sell this part to me?
2019 Sequoia TRD
Here is the ebay link at the bottom to the green one, but the thread right below is the one with the link to jbtaco's conversion which is the bomb. I can't find the part numbers for the lower grill, he's cut his bumper to accomdate the lights and skid plates so he didn't need those pieces. Hope this helps.
2019 Sequoia TRD
So I was scoping out a TRD Pro while I was getting serviced today and the sales guy quoted me $999 for a set of factory TRD Pro running boards, $999 for the grill, needless to say thanks but no thanks. Of interest though is the Pro had one skid plate under the front oil pan but nothing from there back. I was surprised.
Discussion Starter #7
Does anyone know if it is difficult to do a the grille swap on my new Sequoia? Any YouTube’s videos that people have come across?
2019 Sequoia TRD
It got to be pretty simple. The only thing I haven't had a chance to check out is the sales guy told me there are sensors in the grill which I didn't realize, I thought the cameras were all in the module by the rear view mirror. I'll check that out this weekend. One other thing to think about is if you black out or color match your grill you'll have to do the bezel in the lower grill and the fog light surrounds if they're chrome like mine. I did see the TRD pro fog light assemblies on line but they are $495 a set.
Discussion Starter #9
I am trying to remove grille on my own and I’m not having much luck.
I remove the 10 screws.
but it seems as though it is still afixed to the radiator grille assembly (top part between grille and hood) can anyone tell me how to remove grille from that?
I attached the stage I am at. Don’t see the clips they are referring to ANYWHERE. SMH.
Thank you in advance for your help.
Chris
286596
Chris
Chris
Did you ever solve this? I got to the same stage as you.
I recently finished mine.
From there, make sure you put masking tape along the black rubber strip on the hood. Then kind of lift the grille from the hood. You will need to use quite a bit of force. I broke the clip at the edge on both side. They are different than the ones in the center.
The portion in front of the black strip is coming off as your separate the grille and hood.
I bought two new clips from dealer before I can finished the install.
If anyone know where can I mount a front camera ( the tear drop looking one, so it looks OEM) on this grille, please let me know.
1 - 17 of 17 Posts
