The braking issue could be normal on a hybrid, and you may not be familiar with it, as the brakes transition from regenerative to the physical calipers.
Also check that your "brake hold" is off, as that can be disconcerting when they release.
But if you are concerned, make use of your warranty and run it to the dealer... brakes are not something to eff around with.
The red ABS light being on when you are stopped is not normal. Report that to the dealer. That light should only come on momentarily during startup self-check.
On the smell, it's winter and I assume your heater and defroster are running. New vehicles offgas all kinds of "things" that are a part of "that new car smell", and they can smell a bit odd under heat.
