2023 COROLLA XSE HB ENGINE BREAK IN PERIOD, BRAKE BREAKIN PERIOD, FIRST OIL N FILTER CHANGE AND INTERVALS.
1146 Views 35 Replies 15 Participants Last post by  75aces
Just curious as to what is the break in period for this car? 1,000 miles for engine?
200 miles for brakes? (The distance between me and dealership to pick up new car is 60 miles one way)
First oil n filter change to be done at 1,000 miles (DIY-ME) then after that every 5,000 miles?
When driving car to break it in vary speeds (DON'T STAY AT ONE SPEED or engage Cruise control) from 40 MPH to 60 MPH on freeway? Keep RPM's down?
Keep it in what mode for break in? Normal Mode? Over ECO mode or SPORT mode?
Does CVT require some sort of break in period? If so how to drive it?
Did I miss anything??:unsure:
  • Sad
Reactions: 1
Status
Not open for further replies.
1 - 20 of 36 Posts
The owner's manual is your friend. Break in for the brakes? That's a big nothing.
The owner's manual is your friend. Break in for the brakes? That's a big nothing. Did you miss anything? Yeah, you missed looking in the owner's manual.
😎 Nope I haven't got the car yet or the manual and the dealership is 60 miles one way from me. My car is on it's way via ship.
I guess you don't need brakes.🥴
@stingray427 I have to ask my man. Either you are completely old school cars or you don't know much about cars at all with the questions you always ask. No disrespect, just curious friend as we are all here to assist everyone and I can attest that as much as I know, especially old muscle cars, there's still much I don't know. (y)
A bit overdone vs modern engines (even Honda stop using so called "break-in oil" a few years ago). But nothing wrong either if you are inclined to.
Of all what you mention, this is probably the most important.
I'd say please yourself in advance wtih the owner manual, as they are available online. Manuals & Warranties | Toyota Owners
Wasn't there a thread regarding engine break-in where the conclusion was it was best to give it full throttle out of the factory. The explanation was something regarding the seals on cylinders (sorry way too lazy look for it).
@stingray427 had all these questions as well, by lurking here I got:
1. Change initial oil @ 1k
2. Change oil every 6month or 5k, which ever comes first
3. Change cvt oil after 5y
4. Drive it like you stole it (jk)
Reactions: 1
You don't need to break them in. They drove the car off the assembly line and used the brakes just fine, so they will work the way they are built to work.
😁Yes I have not bought a new car since 2005 and 1988.
I hate cell phones/smartphones too which they have made these new cars based as well as video games and other entertainment screens.
I wish we had our old landlines back where we did not have to depend on reception, signal or electricity to operate.
The phone was always clear as a bell didn't have to update it, charge it or worry about it getting hacked and it cost alot less per month.
I didn't have to carry my life in my pocket in a giant phone or go blind from the screen which doesn't help when it makes your eyes go bad.
Buying one of these smartphones is like buying a car put on the payment plan only to have to replace that phone in a few years because of compatibility/viruses or upgrades. Ditto for computers which eventually become obsolete.
I keep my cars 20 to 30+ years. My oldest car was totaled in a hit n run. Now I run with a dash cam front and rear and keep an attorney on on retainer who handles both criminal and civil torts matters.😡
Anyway I'll step down now.
Reactions: 3
@invader did a thread on break in oil change. Even @SuperchargedMR2 mentions it too. Way back when, it was a must to change the oil within the first 500 miles. During that same 500 miles, you weren’t supposed to drive at high rpm’s.
Still applies today. There’s debris from the manufacturing process. The engines aren’t assembled in a clean room.
Reactions: 2
Stingray427 - Why are you so against the modern world ? And why do you have your profile blocked . Sometimes a person can give a better reply if they see the past questions a person has made .
Even in 2008 the first oil change was 5000 miles for a lot of new vehicle , not 1000 miles.
I just drove. did the first change at 9800 miles, second at 18000, third at 36500. I plan to stick to an approximately 8000 mile interval moving forward.
I have gotten a slight "warped brake" feeling recently but I seriously doubt that has anything to do with break in. if anything it's getting somewhat close to new brakes time, probably around 50k miles it will need front pads and I might do rotors at the same time.
Reactions: 1
Really depends on how long you want to keep it and how much maintenance you want or dont want.
Fact based answer:
Toyota has a cutoff point for each type of owner and their use case. The maintenance guide booklet list generally has two designed use cases, one is normal (with the highest interval between each service) and severe (with the least interval between each service).
Determine in which use case you fall under and go from there.
Purely opinion and facts combined here:
Toyota has a breakin period listed in their current model cars. It has not changed for the most part except for the initial oil change (even with their severe duty oil change its set for 5k/6 months unlike previous much earlier). I would still do an early DIY/dealer/indy oil change in the first 1k miles (new engine wear). From there I would follow the severe service maintenance schedule. I say this reading the maintenance guide and if you look at the customer requirement set for a normal toyota maintenance schedule, its very very challenging to meet and most owner use cases just simply categorize them under severe use.
Brakes and varying rpm are still a thing. I was under the impression that 60-0 mph was the only way to bed brakes, but toyota has a TSB that states you can also bed in brakes by doing 20 30-0 mph stops (no cooling or stoppage in between). No cruise control is also important, but again a couple of radar cruise jaunts to try out the system wont hurt anything. I would say itd be bad if you plan to tour cross country with nothing but cruise control in the first 1k.
I wouldnt use eco. It doesnt do any favors. Finally CVT, nothing fancy, keep the fluid fresh like you would run a regular automatic and you should be golden.
Reactions: 1
Engine and transmission are broken in during their assembly and installation into car, performance tested on rollers, nothing special is required for breaking in. Most owners replace oil per maintenance schedule, i.e. at 10K. This has not had impact on engine durability, T is still on top of the charts with engine durability/reliability. I drove mine lightly, not exceeding 70mph and not revving it high for the first 500-600 miles and then it was driven as I always did. My first oil change was at 6K.
I used break-in routine for brakes and bedding of the pads, acceleration to 40-50 and braking not to a full stop, avoiding sudden stops. There are many how-to out there...
I plan to change CVT oil on mine this summer, after 4 years and 50K.
I drive mine in normal mode most of the time, sport mode occasionally, I don't like how car feels in Eco mode - so that's never on...
On the delivery, make sure to ask for QRG, OM and all tags that were hanging inside the car. Those will have answers all your other questions ;)
Reactions: 2
That's very interesting info you state on Toyota breaking in transmission and engine on assembly on rollers.:unsure:
Sounds good. (y)😁
I will likely keep it in "Normal" mode most of the time. Then maybe later on as miles pile up try out the "SPORT" mode because I notice the RPM's go up higher in sport mode.
I know other vehicles have this cylinder deactivation system on V8 engines, Chevrolet AFM? and Dodge ECO mode have them but they just call it a different name and there has been problems associated with this cylinder deactivation system in areas of early valve lifter failures and more stress / uneven engine wear that I have heard about. I don't know if this is true or not.:unsure:
Toyota doesn't have this system just a straight 4 cylinders outright.
I will also make sure I get that original factory window sticker as I have always done.
Toyota does the first oil n filter change at 10,000 miles.
I will do my first oil change with filter alot earlier than that 🤫just for my own assurances using the factory Toyota motor oil and filter.
I will keep those RPM's down and varying the speeds till break in period is over.
Again many thanks for your input(y)(y)😁
Reactions: 2
Owner manual recommendations are only good if you want to do the absolute minimum servicing, while lowering the ownership cost of vehicle as much as possible for first 5 years, while also maintaining the initial new vehicle warranty terms at the same time.
If you don't plan to own your vehicle for much longer than 5YRS/60K before getting rid of it, & don't care what sort of long-term issues you are likely passing along to the next buyer, then go by the owners manual, 10K oil changes, never changing the "lifetime" transmission fluid, etc..
If you do plan to keep your vehicle for a long time & very high miles then the owner manual recommendations are a recipe for headache & expense down the road. Automakers only really care about marketing a vehicle as lower ownership costs/efforts as one way to fool potential customers in their advertising & for it lasting the initial power-train warranty period without issues (hopefully).
Worth watching in full for information purposes & if you plan to keep a vehicle long-term:
Reactions: 1
Owner manual recommendations are only good if you want to do the absolute minimum servicing, while lowering the ownership cost of vehicle as much as possible for first 5 years, while also maintaining the initial new vehicle warranty terms at the same time. If you don't plan to own your vehicle for much longer than 5YRS/60K before getting rid of it, & don't care what sort of long-term issues you are likely passing along to the next buyer, then go by the owners manual, 10K oil changes, never changing the "lifetime" transmission fluid, etc.. If you plan to keep your vehicle for a long time & very high miles then the owner manual recommendations are a recipe for headache & expense down the road. Automakers only really care about marketing a vehicle as lower ownership costs/efforts as one way to fool potential customers in their advertising & for it lasting the initial power-train warranty period without issues (hopefully).
(y) I saw this video some time ago.
No 10K oil n filter changes here.o_O:eek:
Of course I will let dealership do those changes at those intervals for warranty but I will do it myself at earlier intervals.
Same for transmission fluids no such thing as life time fluids. My other car states this in the manual. I put Amsoil in transmission fluid instead.
Toyota.com/owners You can see your owner's manual and the warranty/maintenance guide.
Reactions: 1
Stingray,
You are spot on there is break in for all parts of old or modern cars....... any other theory is BS
I would change the oil at 500 miles and get the debree out of engine from mfg.
Would do again at 1000 miles
Then do your 3000 - 5000 (max)..... oil intervals or 6 mo
IF you have lots of short drives, dirt roads, city drive..... sever service is lower range..... all hwy higher range
Brakes & Tires..... easy driving for 50-200 miles, no hard starts or stops
Belts can twist or budge, brake pads have coatings at times and need to get seated "flat"
Trans has break in too
Trans & Engine learn how you drive...... give it a chance to learn normal driving.
Just set it reg drive mode and leave it there
TheCarCareNut has a nice break in new car video.... will look for it and post next
I would rather buy a used car from you or me
Reactions: 2
Stingray,
:rolleyes:
  • Helpful
Reactions: 1
Never do THIS to your New Toyota and Toyota Hybrid
That is the BREAK IN YOUR NEW TOYOTA
Here is some of the notes from TheCarCareNut put on this video
888,527 views Jan 16, 2021 #thecarcarenut #Toyota
A Toyota Master Diagnostic Technician goes over common mistakes that new Toyota owners do to their brand new Toyota. I cover common things that I see people do to their new cars.
Never do this to your new toyota! People often assume that new cars today don't have a break in period. That is actually not the case as new toyotas have a break in period that should be followed.
Additionally I discuss break in oil changes and oil changes in general. Also I discuss some common scenarios I see with new cars that happen at toyota dealerships.
Also I advise you to check the tire pressure of your new toyota as some of these cars sit on the lot during weather change and their tire pressures are low at times.
I also cover the common overfilling of gas that some new owners do to their new toyota. For more information on damage caused by overfilling your car with gas, See this video : • Never top off you...
I cover items you should do on the day of delivery like inspection the car for damage prior to signing the paper work and then once more before drivinig your new car off the lot. And that burning smell you smell the first few days is normal.
Reactions: 2
1 - 20 of 36 Posts
Status
