1 - 1 of 1 Posts
Located in
20pcs Green 8-Epistar LED Car Truck Dash Speedometer Gauge Indicator Light Lamp
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
20pcs Green 8-Epistar LED Car Truck Dash Speedometer Gauge Indicator Light Lamp Description: *This is for*20 pcsT10*158, 161, 168, 194, 28, 3652, W5W, 2886X*miniature instrumental*led light bulb. Can be used for seat belt warning, auto transmission indicator, brake warning, check engine, directional signal indicator, glove box, hi-beam indicator, instrument, and map lights,etc. For Instrument Twist Lock*Socket : Built to strict quality control standards. Make sure the prongs positions are correct to your application cause some applications the prongs are twisted (Check above photo description pls.). Available to use in CAR/MOTORCYCLE/SCOOTER/TRUCK, Instrument panel indicator light , Interior dome map light. For Pink T10 LED bulbs instrumental panel: This T10 LED will replace socket bulbs number :**158, 161, 168, 194, 28, 3652, W5W, 2886X, 921, 912 . Color:Green LED Type:*T10 8 Epistar*SMD LED Chips. Ultra Bright LED, unique and more vivid color. Low Power Consumption and Low Temperature. Long-lasting Life*50000 hours. Faster on/off response time and vibration resistant. If the LED does not light up, simply Rotating it 180 degrees (reverse the polarity). Package including: 20pcs T10 168 194 led bulbs. IMPORTANT Fitment information provided is for reference only. Please make sure to match the exact part numbers between this part and the part that you are replacing. Contact your mechanics, or send us a message to make sure it matches exactly in case of doubt before purchasing. Seller is not responsible if you are buying non-matching parts. # Notes Year Make Model Trim / Engine 1 Uncertain about compatibility ask us! 2004 Toyota Tacoma Base Crew Cab Pickup 4-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Base Extended Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated Base Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Base Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Base Standard Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated Base Standard Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Crew Cab Pickup 4-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Crew Cab Pickup 4-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Pre Runner Standard Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Standard Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated S-Runner Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated 2 Uncertain about compatibility ask us! 2003 Chevrolet Blazer LS Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 3 Uncertain about compatibility ask us! 2003 Chevrolet Corvette Base Convertible 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated Base Hatchback 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated Z06 Coupe 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated 4 Uncertain about compatibility ask us! 2003 Ford Ranger Edge Extended Cab Pickup 2-Door / 3.0L 182Cu. In. V6 FLEX OHV Naturally Aspirated Edge Standard Cab Pickup 2-Door / 3.0L 182Cu. In. V6 FLEX OHV Naturally Aspirated XL Standard Cab Pickup 2-Door / 2.3L 140Cu. In. l4 GAS DOHC Naturally Aspirated XLT Standard Cab Pickup 2-Door / 3.0L 182Cu. In. V6 FLEX OHV Naturally Aspirated XLT Standard Cab Pickup 2-Door / 3.0L 182Cu. In. V6 GAS OHV Naturally Aspirated 5 Uncertain about compatibility ask us! 2003 Mazda Protege DX Sedan 4-Door / 2.0L 2000CC l4 GAS DOHC Naturally Aspirated LX Sedan 4-Door / 2.0L 2000CC l4 GAS DOHC Naturally Aspirated 6 Uncertain about compatibility ask us! 2003 Toyota Tacoma DLX Extended Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Crew Cab Pickup 4-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Crew Cab Pickup 4-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Pre Runner Standard Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated S-Runner Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated 7 Uncertain about compatibility ask us! 2003 Toyota Tundra Base Standard Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Limited Extended Cab Pickup 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 4-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated SR5 Standard Cab Pickup 2-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 8 Uncertain about compatibility ask us! 2002 Chevrolet Blazer Xtreme Sport Utility 2-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 9 Uncertain about compatibility ask us! 2002 Chevrolet Corvette Base Convertible 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated Base Hatchback 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated 10 Uncertain about compatibility ask us! 2002 Ford Ranger Edge Standard Cab Pickup 2-Door / 3.0L 182Cu. In. V6 GAS OHV Naturally Aspirated XL Extended Cab Pickup 2-Door / 3.0L 182Cu. In. V6 GAS OHV Naturally Aspirated XL Extended Cab Pickup 4-Door / 3.0L 182Cu. In. V6 FLEX OHV Naturally Aspirated 11 Uncertain about compatibility ask us! 2002 Lexus GS300 Base Sedan 4-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 12 Uncertain about compatibility ask us! 2002 Mazda Protege DX Sedan 4-Door / 2.0L 2000CC l4 GAS DOHC Naturally Aspirated 13 Uncertain about compatibility ask us! 2002 Toyota Tacoma DLX Extended Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Pre Runner Crew Cab Pickup 4-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Crew Cab Pickup 4-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated S-Runner Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated 14 Uncertain about compatibility ask us! 2002 Toyota Tundra Base Standard Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Limited Extended Cab Pickup 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 4-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated SR5 Standard Cab Pickup 2-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 15 Uncertain about compatibility ask us! 2001 Chevrolet Blazer Trailblazer Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 16 Uncertain about compatibility ask us! 2001 Chevrolet Corvette Base Convertible 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated Base Hatchback 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated 17 Uncertain about compatibility ask us! 2001 Chevrolet Silverado 1500 Base Standard Cab Pickup 2-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 18 Uncertain about compatibility ask us! 2001 Ford Explorer Sport Sport Utility 2-Door / 4.0L 245Cu. In. V6 GAS SOHC Naturally Aspirated 19 Uncertain about compatibility ask us! 2001 Ford F-150 Harley-Davidson Edition Crew Cab Pickup 4-Door / 5.4L 330Cu. In. V8 GAS SOHC Naturally Aspirated 20 Uncertain about compatibility ask us! 2001 Ford Ranger XL Extended Cab Pickup 4-Door / 3.0L 182Cu. In. V6 FLEX OHV Naturally Aspirated XL Extended Cab Pickup 4-Door / 3.0L 182Cu. In. V6 GAS OHV Naturally Aspirated 21 Uncertain about compatibility ask us! 2001 GMC Jimmy SLE Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 22 Uncertain about compatibility ask us! 2001 Lexus GS300 Base Sedan 4-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 23 Uncertain about compatibility ask us! 2001 Mazda Protege DX Sedan 4-Door / 1.6L 1589CC l4 GAS DOHC Naturally Aspirated 24 Uncertain about compatibility ask us! 2001 Toyota Tacoma DLX Extended Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Pre Runner Crew Cab Pickup 4-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Crew Cab Pickup 4-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated S-Runner Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated 25 Uncertain about compatibility ask us! 2001 Toyota Tundra Base Standard Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Limited Extended Cab Pickup 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 4-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated SR5 Standard Cab Pickup 2-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 26 Uncertain about compatibility ask us! 2000 Chevrolet Blazer LS Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 27 Uncertain about compatibility ask us! 2000 Chevrolet Silverado 1500 Base Standard Cab Pickup 2-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 28 Uncertain about compatibility ask us! 2000 Ford Explorer XL Fleet Sport Utility 4-Door / 4.0L 245Cu. In. V6 GAS OHV Naturally Aspirated 29 Uncertain about compatibility ask us! 2000 Ford F-150 Base Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 30 Uncertain about compatibility ask us! 2000 Ford Ranger XL Standard Cab Pickup 2-Door / 2.5L 153Cu. In. l4 GAS SOHC Naturally Aspirated 31 Uncertain about compatibility ask us! 2000 GMC Jimmy Envoy Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 32 Uncertain about compatibility ask us! 2000 Lexus GS300 Base Sedan 4-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 33 Uncertain about compatibility ask us! 2000 Lexus LS400 Base Sedan 4-Door / 4.0L 3969CC V8 GAS DOHC Naturally Aspirated 34 Uncertain about compatibility ask us! 2000 Lexus SC300 Base Coupe 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 35 Uncertain about compatibility ask us! 2000 Lexus SC400 Base Coupe 2-Door / 4.0L 3969CC V8 GAS DOHC Naturally Aspirated 36 Uncertain about compatibility ask us! 2000 Mazda MPV DX Standard Passenger Van 3-Door / 2.5L 2497CC V6 GAS DOHC Naturally Aspirated ES Standard Passenger Van 3-Door / 2.5L 2497CC V6 GAS DOHC Naturally Aspirated 37 Uncertain about compatibility ask us! 2000 Mazda Protege DX Sedan 4-Door / 1.6L 1589CC l4 GAS DOHC Naturally Aspirated 38 Uncertain about compatibility ask us! 2000 Subaru Forester Base Wagon 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated L Wagon 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated S Wagon 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 39 Uncertain about compatibility ask us! 2000 Toyota Tacoma DLX Extended Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Limited Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated 40 Uncertain about compatibility ask us! 2000 Toyota Tundra Base Standard Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Limited Extended Cab Pickup 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 4-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated SR5 Standard Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated SR5 Standard Cab Pickup 2-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 41 Uncertain about compatibility ask us! 1999 Chevrolet Blazer Base Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 42 Uncertain about compatibility ask us! 1999 Chevrolet Tahoe Base Sport Utility 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated 43 Uncertain about compatibility ask us! 1999 Ford Contour SE Sedan 4-Door / 2.0L 1989CC 121Cu. In. l4 GAS DOHC Naturally Aspirated 44 Uncertain about compatibility ask us! 1999 Ford Expedition Eddie Bauer Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 45 Uncertain about compatibility ask us! 1999 Ford Explorer XL Sport Utility 4-Door / 4.0L 245Cu. In. V6 GAS SOHC Naturally Aspirated 46 Uncertain about compatibility ask us! 1999 Ford F-150 Base Standard Cab Pickup 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 47 Uncertain about compatibility ask us! 1999 Ford Mustang GT Coupe 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 48 Uncertain about compatibility ask us! 1999 Ford Ranger XL Extended Cab Pickup 4-Door / 3.0L 182Cu. In. V6 FLEX OHV Naturally Aspirated XL Standard Cab Pickup 2-Door / 2.5L 153Cu. In. l4 GAS SOHC Naturally Aspirated 49 Uncertain about compatibility ask us! 1999 Ford Taurus LX Sedan 4-Door / 3.0L 182Cu. In. V6 FLEX OHV Naturally Aspirated 50 Uncertain about compatibility ask us! 1999 GMC Jimmy Envoy Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated SL Sport Utility 2-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 51 Uncertain about compatibility ask us! 1999 Lexus LS400 Base Sedan 4-Door / 4.0L 3969CC V8 GAS DOHC Naturally Aspirated 52 Uncertain about compatibility ask us! 1999 Lexus SC300 Base Coupe 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 53 Uncertain about compatibility ask us! 1999 Lexus SC400 Base Coupe 2-Door / 4.0L 3969CC V8 GAS DOHC Naturally Aspirated 54 Uncertain about compatibility ask us! 1999 Mazda Protege DX Sedan 4-Door / 1.6L 1589CC l4 GAS DOHC Naturally Aspirated 55 Uncertain about compatibility ask us! 1999 Subaru Forester Base Wagon 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated L Wagon 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated S Wagon 4-Door / 2.5L 2458CC H4 GAS SOHC Naturally Aspirated 56 Uncertain about compatibility ask us! 1999 Toyota Land Cruiser Base Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 57 Uncertain about compatibility ask us! 1999 Toyota Tacoma DLX Extended Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Limited Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated 58 Uncertain about compatibility ask us! 1998 Chevrolet Blazer Base Sport Utility 2-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 59 Uncertain about compatibility ask us! 1998 Chevrolet Tahoe Base Sport Utility 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated Base Sport Utility 2-Door / 6.5L 395Cu. In. V8 DIESEL OHV Turbocharged 60 Uncertain about compatibility ask us! 1998 Ford Contour GL Sedan 4-Door / 2.0L 1989CC 121Cu. In. l4 BI-FUEL DOHC Naturally Aspirated 61 Uncertain about compatibility ask us! 1998 Ford Expedition Eddie Bauer Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 62 Uncertain about compatibility ask us! 1998 Ford Explorer XLT Sport Utility 4-Door / 5.0L 302Cu. In. V8 GAS OHV Naturally Aspirated 63 Uncertain about compatibility ask us! 1998 Ford F-150 Base Extended Cab Pickup 3-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 64 Uncertain about compatibility ask us! 1998 Ford Ranger Splash Extended Cab Pickup 4-Door / 3.0L 182Cu. In. V6 GAS OHV Naturally Aspirated 65 Uncertain about compatibility ask us! 1998 Ford Taurus LX Sedan 4-Door / 3.0L 182Cu. In. V6 GAS DOHC Naturally Aspirated SE Sedan 4-Door / 3.0L 182Cu. In. V6 FLEX OHV Naturally Aspirated 66 Uncertain about compatibility ask us! 1998 GMC Jimmy Envoy Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated SLS Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 67 Uncertain about compatibility ask us! 1998 Lexus GS300 Base Sedan 4-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 68 Uncertain about compatibility ask us! 1998 Lexus LS400 Base Sedan 4-Door / 4.0L 3969CC V8 GAS DOHC Naturally Aspirated 69 Uncertain about compatibility ask us! 1998 Lexus SC300 Base Coupe 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 70 Uncertain about compatibility ask us! 1998 Lexus SC400 Base Coupe 2-Door / 4.0L 3969CC V8 GAS DOHC Naturally Aspirated 71 Uncertain about compatibility ask us! 1998 Lincoln Mark VIII Base Sedan 2-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated LSC Sedan 2-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 72 Uncertain about compatibility ask us! 1998 Lincoln Town Car Base Limousine 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 73 Uncertain about compatibility ask us! 1998 Mazda Protege DX Sedan 4-Door / 1.5L 1489CC l4 GAS DOHC Naturally Aspirated 74 Uncertain about compatibility ask us! 1998 Nissan 240SX Base Coupe 2-Door / 2.4L 2389CC l4 GAS DOHC Naturally Aspirated 75 Uncertain about compatibility ask us! 1998 Subaru Forester Base Wagon 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated L Wagon 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated S Wagon 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated 76 Uncertain about compatibility ask us! 1998 Subaru Legacy Brighton Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated GT Limited Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated GT Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated GT Wagon 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated L Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated L Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated Outback Wagon 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated Postal Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated 77 Uncertain about compatibility ask us! 1998 Toyota Land Cruiser Base Sport Utility 4-Door / 4.7L 4663CC 285Cu. In. V8 GAS DOHC Naturally Aspirated 78 Uncertain about compatibility ask us! 1998 Toyota Supra Base Hatchback 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated Twin Turbo Hatchback 2-Door / 3.0L 2997CC l6 GAS DOHC Turbocharged 79 Uncertain about compatibility ask us! 1998 Toyota Tacoma DLX Extended Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Limited Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated Pre Runner Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated 80 Uncertain about compatibility ask us! 1997 Chevrolet Camaro Base Convertible 2-Door / 3.8L 3800CC 231Cu. In. V6 GAS OHV Naturally Aspirated Base Coupe 2-Door / 3.8L 3800CC 231Cu. In. V6 GAS OHV Naturally Aspirated 81 Uncertain about compatibility ask us! 1997 Chevrolet Tahoe Base Sport Utility 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated Base Sport Utility 2-Door / 6.5L 395Cu. In. V8 DIESEL OHV Turbocharged LS Sport Utility 4-Door / 6.5L 395Cu. In. V8 DIESEL OHV Turbocharged 82 Uncertain about compatibility ask us! 1997 Ford Contour GL Sedan 4-Door / 2.0L 1989CC 121Cu. In. l4 BI-FUEL DOHC Naturally Aspirated 83 Uncertain about compatibility ask us! 1997 Ford Expedition Eddie Bauer Sport Utility 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 84 Uncertain about compatibility ask us! 1997 Ford Explorer XLT Sport Utility 4-Door / 5.0L 302Cu. In. V8 GAS OHV Naturally Aspirated 85 Uncertain about compatibility ask us! 1997 Ford F-150 Base Extended Cab Pickup 3-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 86 Uncertain about compatibility ask us! 1997 Ford Mustang GT Coupe 2-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 87 Uncertain about compatibility ask us! 1997 Ford Ranger STX Extended Cab Pickup 2-Door / 4.0L 245Cu. In. V6 GAS OHV Naturally Aspirated 88 Uncertain about compatibility ask us! 1997 Ford Taurus GL Sedan 4-Door / 3.0L 182Cu. In. V6 FLEX OHV Naturally Aspirated SHO Sedan 4-Door / 3.4L 207Cu. In. V8 GAS DOHC Naturally Aspirated 89 Uncertain about compatibility ask us! 1997 GMC Jimmy SL Sport Utility 2-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated SL Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 90 Uncertain about compatibility ask us! 1997 Lexus SC300 Base Coupe 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 91 Uncertain about compatibility ask us! 1997 Lexus SC400 Base Coupe 2-Door / 4.0L 3969CC V8 GAS DOHC Naturally Aspirated 92 Uncertain about compatibility ask us! 1997 Lincoln Mark VIII Base Sedan 2-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated LSC Sedan 2-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 93 Uncertain about compatibility ask us! 1997 Lincoln Town Car Base Limousine 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 94 Uncertain about compatibility ask us! 1997 Mazda 626 DX Sedan 4-Door / 2.0L 1991CC l4 GAS DOHC Naturally Aspirated 95 Uncertain about compatibility ask us! 1997 Mazda Miata Base Convertible 2-Door / 1.8L 1839CC l4 GAS DOHC Naturally Aspirated 96 Uncertain about compatibility ask us! 1997 Mazda MPV ES Standard Passenger Van 3-Door / 3.0L 2954CC V6 GAS SOHC Naturally Aspirated 97 Uncertain about compatibility ask us! 1997 Mazda Protege DX Sedan 4-Door / 1.5L 1489CC l4 GAS DOHC Naturally Aspirated 98 Uncertain about compatibility ask us! 1997 Nissan 240SX Base Coupe 2-Door / 2.4L 2389CC l4 GAS DOHC Naturally Aspirated 99 Uncertain about compatibility ask us! 1997 Subaru Legacy Brighton Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated GT Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated GT Wagon 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated L Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated L Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LSi Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated LSi Wagon 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated Outback Limited Wagon 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated Outback Wagon 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated Postal Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated 100 Uncertain about compatibility ask us! 1997 Toyota Avalon XL Sedan 4-Door / 3.0L 2995CC V6 GAS DOHC Naturally Aspirated XLS Sedan 4-Door / 3.0L 2995CC V6 GAS DOHC Naturally Aspirated 101 Uncertain about compatibility ask us! 1997 Toyota Land Cruiser Base Sport Utility 4-Door / 4.5L 4477CC l6 GAS DOHC Naturally Aspirated 102 Uncertain about compatibility ask us! 1997 Toyota Supra Base Hatchback 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated Twin Turbo Hatchback 2-Door / 3.0L 2997CC l6 GAS DOHC Turbocharged 103 Uncertain about compatibility ask us! 1997 Toyota Tacoma DLX Extended Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated 104 Uncertain about compatibility ask us! 1996 Chevrolet Tahoe Base Sport Utility 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated 105 Uncertain about compatibility ask us! 1996 Ford Contour GL Sedan 4-Door / 2.0L 1989CC 121Cu. In. l4 BI-FUEL DOHC Naturally Aspirated 106 Uncertain about compatibility ask us! 1996 Ford Escort Base Hatchback 2-Door / 1.9L 116Cu. In. l4 GAS SOHC Naturally Aspirated 107 Uncertain about compatibility ask us! 1996 Ford Explorer Sport Sport Utility 2-Door / 4.0L 245Cu. In. V6 GAS OHV Naturally Aspirated 108 Uncertain about compatibility ask us! 1996 Ford F-150 XL Standard Cab Pickup 2-Door / 4.9L 300Cu. In. l6 GAS OHV Naturally Aspirated 109 Uncertain about compatibility ask us! 1996 Ford F-250 XLT Crew Cab Pickup 4-Door / 4.9L 300Cu. In. l6 GAS OHV Naturally Aspirated 110 Uncertain about compatibility ask us! 1996 Ford F-350 Special Standard Cab Pickup 2-Door / 4.9L 300Cu. In. l6 GAS OHV Naturally Aspirated XL Cab & Chassis 2-Door / 4.9L 300Cu. In. l6 GAS OHV Naturally Aspirated XL Crew Cab Pickup 4-Door / 7.3L 445Cu. In. V8 DIESEL OHV Turbocharged XL Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Turbocharged XLT Crew Cab Pickup 4-Door / 7.3L 445Cu. In. V8 DIESEL OHV Turbocharged XLT Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Turbocharged 111 Uncertain about compatibility ask us! 1996 Ford Taurus GL Wagon 4-Door / 3.0L 182Cu. In. V6 FLEX OHV Naturally Aspirated LX Sedan 4-Door / 3.0L 182Cu. In. V6 GAS DOHC Naturally Aspirated SHO Sedan 4-Door / 3.4L 207Cu. In. V8 GAS DOHC Naturally Aspirated 112 Uncertain about compatibility ask us! 1996 GMC Jimmy Base Sport Utility 2-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated SL Sport Utility 2-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated SL Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 113 Uncertain about compatibility ask us! 1996 Lexus GS300 Base Sedan 4-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 114 Uncertain about compatibility ask us! 1996 Lexus LX450 Base Sport Utility 4-Door / 4.5L 4477CC l6 GAS DOHC Naturally Aspirated 115 Uncertain about compatibility ask us! 1996 Lexus SC400 Base Coupe 2-Door / 4.0L 3969CC V8 GAS DOHC Naturally Aspirated 116 Uncertain about compatibility ask us! 1996 Lincoln Continental Spinnaker Edition Sedan 4-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 117 Uncertain about compatibility ask us! 1996 Lincoln Mark VIII LSC Sedan 2-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 118 Uncertain about compatibility ask us! 1996 Lincoln Town Car Base Limousine 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated Cartier Sedan 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated Signature Sedan 4-Door / 4.6L 281Cu. In. V8 GAS SOHC Naturally Aspirated 119 Uncertain about compatibility ask us! 1996 Mazda 626 DX Sedan 4-Door / 2.0L 1991CC l4 GAS DOHC Naturally Aspirated 120 Uncertain about compatibility ask us! 1996 Mazda Miata Base Convertible 2-Door / 1.8L 1839CC l4 GAS DOHC Naturally Aspirated 121 Uncertain about compatibility ask us! 1996 Mazda MPV LX Standard Passenger Van 3-Door / 3.0L 2954CC V6 GAS SOHC Naturally Aspirated 122 Uncertain about compatibility ask us! 1996 Mazda MX-6 Base Coupe 2-Door / 2.0L 1991CC l4 GAS DOHC Naturally Aspirated 123 Uncertain about compatibility ask us! 1996 Mazda Protege DX Sedan 4-Door / 1.5L 1489CC l4 GAS DOHC Naturally Aspirated 124 Uncertain about compatibility ask us! 1996 Mitsubishi Mirage LS Coupe 2-Door / 1.8L 1834CC 112Cu. In. l4 GAS SOHC Naturally Aspirated S Coupe 2-Door / 1.5L 1468CC 90Cu. In. l4 GAS SOHC Naturally Aspirated S Sedan 4-Door / 1.5L 1468CC 90Cu. In. l4 GAS SOHC Naturally Aspirated 125 Uncertain about compatibility ask us! 1996 Subaru Legacy Brighton Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated GT Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated GT Wagon 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated L Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated L Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LS Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LS Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LSi Sedan 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated LSi Wagon 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated Outback Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated Outback Wagon 4-Door / 2.5L 2458CC H4 GAS DOHC Naturally Aspirated Postal Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated 126 Uncertain about compatibility ask us! 1996 Toyota Avalon XL Sedan 4-Door / 3.0L 2995CC V6 GAS DOHC Naturally Aspirated 127 Uncertain about compatibility ask us! 1996 Toyota Land Cruiser Base Sport Utility 4-Door / 4.5L 4477CC l6 GAS DOHC Naturally Aspirated 128 Uncertain about compatibility ask us! 1996 Toyota Supra Base Hatchback 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated Twin Turbo Hatchback 2-Door / 3.0L 2997CC l6 GAS DOHC Turbocharged 129 Uncertain about compatibility ask us! 1996 Toyota Tacoma DLX Extended Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated 130 Uncertain about compatibility ask us! 1996 Toyota Tercel DX Sedan 2-Door / 1.5L 1497CC l4 GAS DOHC Naturally Aspirated DX Sedan 4-Door / 1.5L 1497CC l4 GAS DOHC Naturally Aspirated STD Sedan 2-Door / 1.5L 1497CC l4 GAS DOHC Naturally Aspirated 131 Uncertain about compatibility ask us! 1995 Chevrolet Astro Base Standard Cargo Van 3-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 132 Uncertain about compatibility ask us! 1995 Chevrolet Tahoe Base Sport Utility 2-Door / 6.5L 395Cu. In. V8 DIESEL OHV Turbocharged 133 Uncertain about compatibility ask us! 1995 Ford Contour GL Sedan 4-Door / 2.5L 2450CC 155Cu. In. V6 GAS DOHC Naturally Aspirated 134 Uncertain about compatibility ask us! 1995 Ford Escort Base Hatchback 2-Door / 1.9L 116Cu. In. l4 GAS SOHC Naturally Aspirated 135 Uncertain about compatibility ask us! 1995 Ford Explorer Expedition Sport Utility 2-Door / 4.0L 245Cu. In. V6 GAS OHV Naturally Aspirated 136 Uncertain about compatibility ask us! 1995 Ford F-150 Special Extended Cab Pickup 2-Door / 4.9L 300Cu. In. l6 GAS OHV Naturally Aspirated 137 Uncertain about compatibility ask us! 1995 Ford F-250 XL Crew Cab Pickup 4-Door / 5.0L 302Cu. In. V8 GAS OHV Naturally Aspirated 138 Uncertain about compatibility ask us! 1995 Ford F-350 Special Standard Cab Pickup 2-Door / 4.9L 300Cu. In. l6 GAS OHV Naturally Aspirated XL Crew Cab Pickup 4-Door / 7.3L 445Cu. In. V8 DIESEL OHV Turbocharged XL Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Turbocharged XLT Crew Cab Pickup 4-Door / 7.3L 445Cu. In. V8 DIESEL OHV Turbocharged XLT Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Turbocharged 139 Uncertain about compatibility ask us! 1995 Ford Taurus LX Sedan 4-Door / 3.0L 182Cu. In. V6 GAS OHV Naturally Aspirated SE Sedan 4-Door / 3.8L 232Cu. In. V6 GAS OHV Naturally Aspirated SHO Sedan 4-Door / 3.2L 195Cu. In. V6 GAS DOHC Naturally Aspirated 140 Uncertain about compatibility ask us! 1995 GMC Jimmy Base Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated SL Sport Utility 2-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated SLE Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated SLS Sport Utility 2-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated SLT Sport Utility 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated 141 Uncertain about compatibility ask us! 1995 Lexus GS300 Base Sedan 4-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 142 Uncertain about compatibility ask us! 1995 Lexus SC300 Base Coupe 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 143 Uncertain about compatibility ask us! 1995 Lexus SC400 Base Coupe 2-Door / 4.0L 3967CC V8 GAS DOHC Naturally Aspirated 144 Uncertain about compatibility ask us! 1995 Lincoln Mark VIII LSC Sedan 2-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 145 Uncertain about compatibility ask us! 1995 Mazda 626 DX Sedan 4-Door / 2.0L 1991CC l4 GAS DOHC Naturally Aspirated 146 Uncertain about compatibility ask us! 1995 Mazda Miata Base Convertible 2-Door / 1.8L 1839CC l4 GAS DOHC Naturally Aspirated 147 Uncertain about compatibility ask us! 1995 Mazda MX-3 Base Coupe 2-Door / 1.6L 1597CC l4 GAS DOHC Naturally Aspirated 148 Uncertain about compatibility ask us! 1995 Mazda MX-6 Base Coupe 2-Door / 2.0L 1991CC l4 GAS DOHC Naturally Aspirated 149 Uncertain about compatibility ask us! 1995 Mazda Protege DX Sedan 4-Door / 1.5L 1489CC l4 GAS DOHC Naturally Aspirated 150 Uncertain about compatibility ask us! 1995 Mitsubishi Mirage ES Coupe 2-Door / 1.5L 1468CC 90Cu. In. l4 GAS SOHC Naturally Aspirated ES Sedan 4-Door / 1.8L 1834CC 112Cu. In. l4 GAS SOHC Naturally Aspirated LS Coupe 2-Door / 1.8L 1834CC 112Cu. In. l4 GAS SOHC Naturally Aspirated S Coupe 2-Door / 1.5L 1468CC 90Cu. In. l4 GAS SOHC Naturally Aspirated S Sedan 4-Door / 1.5L 1468CC 90Cu. In. l4 GAS SOHC Naturally Aspirated 151 Uncertain about compatibility ask us! 1995 Nissan 240SX Base Coupe 2-Door / 2.4L 2389CC l4 GAS DOHC Naturally Aspirated 152 Uncertain about compatibility ask us! 1995 Subaru Legacy Base Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated Brighton Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated L Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated L Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LS Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LS Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LSi Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LSi Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated Outback Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated Postal Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated 153 Uncertain about compatibility ask us! 1995 Toyota Avalon XL Sedan 4-Door / 3.0L 2995CC V6 GAS DOHC Naturally Aspirated XLS Sedan 4-Door / 3.0L 2995CC V6 GAS DOHC Naturally Aspirated 154 Uncertain about compatibility ask us! 1995 Toyota Land Cruiser Base Sport Utility 4-Door / 4.5L 4477CC l6 GAS DOHC Naturally Aspirated 155 Uncertain about compatibility ask us! 1995 Toyota MR2 Base Coupe 2-Door / 2.2L 2164CC l4 GAS DOHC Naturally Aspirated Turbo Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged 156 Uncertain about compatibility ask us! 1995 Toyota Supra Base Hatchback 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated Twin Turbo Hatchback 2-Door / 3.0L 2997CC l6 GAS DOHC Turbocharged 157 Uncertain about compatibility ask us! 1995 Toyota Tacoma DLX Extended Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.4L 2438CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 2.7L 2694CC l4 GAS DOHC Naturally Aspirated DLX Standard Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated SR5 Extended Cab Pickup 2-Door / 3.4L 3378CC V6 GAS DOHC Naturally Aspirated 158 Uncertain about compatibility ask us! 1995 Toyota Tercel DX Sedan 2-Door / 1.5L 1497CC l4 GAS DOHC Naturally Aspirated DX Sedan 4-Door / 1.5L 1497CC l4 GAS DOHC Naturally Aspirated STD Sedan 2-Door / 1.5L 1497CC l4 GAS DOHC Naturally Aspirated 159 Uncertain about compatibility ask us! 1994 Ford Bronco XL Sport Utility 2-Door / 5.0L 302Cu. In. V8 GAS OHV Naturally Aspirated 160 Uncertain about compatibility ask us! 1994 Ford F-150 Lightning Standard Cab Pickup 2-Door / 5.8L 351Cu. In. V8 GAS OHV Naturally Aspirated 161 Uncertain about compatibility ask us! 1994 Ford F-250 XL Extended Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated 162 Uncertain about compatibility ask us! 1994 Ford F-350 XL Crew Cab Pickup 4-Door / 7.3L 445Cu. In. V8 DIESEL OHV Turbocharged XL Standard Cab Pickup 2-Door / 5.8L 351Cu. In. V8 GAS OHV Naturally Aspirated XL Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Turbocharged XLT Crew Cab Pickup 4-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated XLT Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated 163 Uncertain about compatibility ask us! 1994 Ford Mustang GT Coupe 2-Door / 5.0L 302Cu. In. V8 GAS OHV Naturally Aspirated 164 Uncertain about compatibility ask us! 1994 Lexus GS300 Base Sedan 4-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 165 Uncertain about compatibility ask us! 1994 Lexus SC300 Base Coupe 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 166 Uncertain about compatibility ask us! 1994 Lexus SC400 Base Coupe 2-Door / 4.0L 3967CC V8 GAS DOHC Naturally Aspirated 167 Uncertain about compatibility ask us! 1994 Mazda 626 LX Sedan 4-Door / 2.0L 1991CC l4 GAS DOHC Naturally Aspirated 168 Uncertain about compatibility ask us! 1994 Mazda 929 Base Sedan 4-Door / 3.0L 2954CC V6 GAS DOHC Naturally Aspirated 169 Uncertain about compatibility ask us! 1994 Mazda Miata Base Convertible 2-Door / 1.8L 1839CC l4 GAS DOHC Naturally Aspirated 170 Uncertain about compatibility ask us! 1994 Mazda MX-3 Base Coupe 2-Door / 1.6L 1597CC l4 GAS DOHC Naturally Aspirated 171 Uncertain about compatibility ask us! 1994 Mazda MX-6 Base Coupe 2-Door / 2.0L 1991CC l4 GAS DOHC Naturally Aspirated 172 Uncertain about compatibility ask us! 1994 Mitsubishi Mirage ES Coupe 2-Door / 1.5L 1468CC 90Cu. In. l4 GAS SOHC Naturally Aspirated ES Sedan 4-Door / 1.8L 1834CC 112Cu. In. l4 GAS SOHC Naturally Aspirated LS Coupe 2-Door / 1.8L 1834CC 112Cu. In. l4 GAS SOHC Naturally Aspirated LS Sedan 4-Door / 1.8L 1834CC 112Cu. In. l4 GAS SOHC Naturally Aspirated S Coupe 2-Door / 1.5L 1468CC 90Cu. In. l4 GAS SOHC Naturally Aspirated S Sedan 4-Door / 1.5L 1468CC 90Cu. In. l4 GAS SOHC Naturally Aspirated 173 Uncertain about compatibility ask us! 1994 Subaru Legacy Alpine Sport Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated GT Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated L Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated L Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LS Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LS Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LSi Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LSi Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated Outdoor Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated Sport Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Turbocharged Sun Sport Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated Touring Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated 174 Uncertain about compatibility ask us! 1994 Toyota MR2 Base Coupe 2-Door / 2.2L 2164CC l4 GAS DOHC Naturally Aspirated Turbo Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged 175 Uncertain about compatibility ask us! 1994 Toyota Supra Base Hatchback 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated Twin Turbo Hatchback 2-Door / 3.0L 2997CC l6 GAS DOHC Turbocharged 176 Uncertain about compatibility ask us! 1994 Toyota Tercel DLX Sedan 2-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated DLX Sedan 4-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated LE Sedan 4-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated STD Sedan 2-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated 177 Uncertain about compatibility ask us! 1993 Ford Aerostar XLT Sport Mini Passenger Van 2-Door / 3.0L 182Cu. In. V6 GAS OHV Naturally Aspirated 178 Uncertain about compatibility ask us! 1993 Ford Bronco XL Sport Utility 2-Door / 5.0L 302Cu. In. V8 GAS OHV Naturally Aspirated 179 Uncertain about compatibility ask us! 1993 Ford F-150 Lightning Standard Cab Pickup 2-Door / 5.8L 351Cu. In. V8 GAS OHV Naturally Aspirated 180 Uncertain about compatibility ask us! 1993 Ford F-250 XLT Extended Cab Pickup 2-Door / 7.5L 460Cu. In. V8 GAS OHV Naturally Aspirated 181 Uncertain about compatibility ask us! 1993 Ford F-350 XL Crew Cab Pickup 4-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated XL Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Turbocharged XLT Crew Cab Pickup 4-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated XLT Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Turbocharged 182 Uncertain about compatibility ask us! 1993 Honda Accord DX Coupe 2-Door / 2.2L 2156CC l4 GAS SOHC Naturally Aspirated 183 Uncertain about compatibility ask us! 1993 Lexus GS300 Base Sedan 4-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 184 Uncertain about compatibility ask us! 1993 Lincoln Mark VIII Base Sedan 2-Door / 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated 185 Uncertain about compatibility ask us! 1993 Mazda 323 SE Hatchback 2-Door / 1.6L 1597CC l4 GAS SOHC Naturally Aspirated 186 Uncertain about compatibility ask us! 1993 Mazda 626 DX Sedan 4-Door / 2.0L 1991CC l4 GAS DOHC Naturally Aspirated LX Sedan 4-Door / 2.0L 1991CC l4 GAS DOHC Naturally Aspirated 187 Uncertain about compatibility ask us! 1993 Mazda 929 Base Sedan 4-Door / 3.0L 2954CC V6 GAS DOHC Naturally Aspirated 188 Uncertain about compatibility ask us! 1993 Mazda Miata Base Convertible 2-Door / 1.6L 1597CC l4 GAS DOHC Naturally Aspirated 189 Uncertain about compatibility ask us! 1993 Mazda MX-3 Base Coupe 2-Door / 1.6L 1597CC l4 GAS SOHC Naturally Aspirated 190 Uncertain about compatibility ask us! 1993 Mazda MX-6 Base Coupe 2-Door / 2.0L 1991CC l4 GAS DOHC Naturally Aspirated 191 Uncertain about compatibility ask us! 1993 Mitsubishi Mirage ES Coupe 2-Door / 1.5L 1468CC 90Cu. In. l4 GAS SOHC Naturally Aspirated ES Sedan 4-Door / 1.8L 1834CC 112Cu. In. l4 GAS SOHC Naturally Aspirated LS Coupe 2-Door / 1.8L 1834CC 112Cu. In. l4 GAS SOHC Naturally Aspirated LS Sedan 4-Door / 1.8L 1834CC 112Cu. In. l4 GAS SOHC Naturally Aspirated S Coupe 2-Door / 1.5L 1468CC 90Cu. In. l4 GAS SOHC Naturally Aspirated S Sedan 4-Door / 1.5L 1468CC 90Cu. In. l4 GAS SOHC Naturally Aspirated 192 Uncertain about compatibility ask us! 1993 Nissan 240SX Base Coupe 2-Door / 2.4L 2389CC l4 GAS DOHC Naturally Aspirated 193 Uncertain about compatibility ask us! 1993 Subaru Legacy L Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated L Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LS Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LS Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LSi Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LSi Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated Sport Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Turbocharged 194 Uncertain about compatibility ask us! 1993 Toyota MR2 Base Coupe 2-Door / 2.2L 2164CC l4 GAS DOHC Naturally Aspirated Turbo Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged 195 Uncertain about compatibility ask us! 1993 Toyota Supra Base Hatchback 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated Twin Turbo Hatchback 2-Door / 3.0L 2997CC l6 GAS DOHC Turbocharged 196 Uncertain about compatibility ask us! 1993 Toyota Tercel DLX Sedan 2-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated DLX Sedan 4-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated LE Sedan 4-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated STD Sedan 2-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated 197 Uncertain about compatibility ask us! 1992 Chevrolet Camaro RS Convertible 2-Door / 3.1L 189Cu. In. V6 GAS OHV Naturally Aspirated RS Heritage Edition Convertible 2-Door / 5.0L 305Cu. In. V8 GAS OHV Naturally Aspirated Z28 Coupe 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated Z28 Heritage Edition Coupe 2-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated 198 Uncertain about compatibility ask us! 1992 Ford Bronco XL Sport Utility 2-Door / 4.9L 300Cu. In. l6 GAS OHV Naturally Aspirated 199 Uncertain about compatibility ask us! 1992 Ford F-150 XL Extended Cab Pickup 2-Door / 4.9L 300Cu. In. l6 GAS OHV Naturally Aspirated 200 Uncertain about compatibility ask us! 1992 Ford F-250 XL Extended Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated 201 Uncertain about compatibility ask us! 1992 Ford F-350 XL Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated 202 Uncertain about compatibility ask us! 1992 Honda Accord DX Coupe 2-Door / 2.2L 2156CC l4 GAS SOHC Naturally Aspirated 203 Uncertain about compatibility ask us! 1992 Infiniti M30 Base Convertible 2-Door / 3.0L 2960CC 181Cu. In. V6 GAS SOHC Naturally Aspirated Base Coupe 2-Door / 3.0L 2960CC 181Cu. In. V6 GAS SOHC Naturally Aspirated 204 Uncertain about compatibility ask us! 1992 Lexus SC300 Base Coupe 2-Door / 3.0L 2997CC l6 GAS DOHC Naturally Aspirated 205 Uncertain about compatibility ask us! 1992 Lexus SC400 Base Coupe 2-Door / 4.0L 3967CC V8 GAS DOHC Naturally Aspirated 206 Uncertain about compatibility ask us! 1992 Mazda 323 Base Hatchback 2-Door / 1.6L 1597CC l4 GAS SOHC Naturally Aspirated 207 Uncertain about compatibility ask us! 1992 Mazda 929 Base Sedan 4-Door / 3.0L 2954CC V6 GAS DOHC Naturally Aspirated 208 Uncertain about compatibility ask us! 1992 Mazda MX-3 Base Coupe 2-Door / 1.6L 1597CC l4 GAS SOHC Naturally Aspirated 209 Uncertain about compatibility ask us! 1992 Nissan 240SX Base Coupe 2-Door / 2.4L 2389CC l4 GAS DOHC Naturally Aspirated Base Hatchback 2-Door / 2.4L 2389CC l4 GAS DOHC Naturally Aspirated 210 Uncertain about compatibility ask us! 1992 Subaru Legacy L Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated L Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LS Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LS Wagon 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated LSi Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Naturally Aspirated Sport Sedan 4-Door / 2.2L 2212CC H4 GAS SOHC Turbocharged 211 Uncertain about compatibility ask us! 1992 Toyota Celica All Trac Hatchback 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged GT Convertible 2-Door / 2.2L 2164CC l4 GAS DOHC Naturally Aspirated GT Coupe 2-Door / 2.2L 2164CC l4 GAS DOHC Naturally Aspirated GT Hatchback 2-Door / 2.2L 2164CC l4 GAS DOHC Naturally Aspirated GTS Hatchback 2-Door / 2.2L 2164CC l4 GAS DOHC Naturally Aspirated ST Coupe 2-Door / 1.6L 1587CC l4 GAS DOHC Naturally Aspirated 212 Uncertain about compatibility ask us! 1992 Toyota Supra Base Hatchback 2-Door / 3.0L 2954CC l6 GAS DOHC Naturally Aspirated Turbo Hatchback 2-Door / 3.0L 2954CC l6 GAS DOHC Turbocharged 213 Uncertain about compatibility ask us! 1992 Toyota Tercel DLX Sedan 2-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated DLX Sedan 4-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated LE Sedan 4-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated STD Sedan 2-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated 214 Uncertain about compatibility ask us! 1991 Acura Integra RS Hatchback 3-Door / 1.8L 1834CC l4 GAS DOHC Naturally Aspirated 215 Uncertain about compatibility ask us! 1991 Ford F-150 XL Extended Cab Pickup 2-Door / 4.9L 300Cu. In. l6 GAS OHV Naturally Aspirated 216 Uncertain about compatibility ask us! 1991 Ford F-250 XL Extended Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated 217 Uncertain about compatibility ask us! 1991 Ford F-350 XL Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated 218 Uncertain about compatibility ask us! 1991 Honda Accord DX Coupe 2-Door / 2.2L 2156CC l4 GAS SOHC Naturally Aspirated DX Sedan 4-Door / 2.2L 2156CC l4 GAS SOHC Naturally Aspirated 219 Uncertain about compatibility ask us! 1991 Honda Prelude Si 4WS Coupe 2-Door / 2.1L 2056CC l4 GAS DOHC Naturally Aspirated Si Coupe 2-Door / 2.1L 2056CC l4 GAS DOHC Naturally Aspirated 220 Uncertain about compatibility ask us! 1991 Infiniti M30 Base Convertible 2-Door / 3.0L 2960CC 181Cu. In. V6 GAS SOHC Naturally Aspirated Base Coupe 2-Door / 3.0L 2960CC 181Cu. In. V6 GAS SOHC Naturally Aspirated 221 Uncertain about compatibility ask us! 1991 Mazda 929 Base Sedan 4-Door / 3.0L 2954CC V6 GAS SOHC Naturally Aspirated 222 Uncertain about compatibility ask us! 1991 Nissan 240SX Base Coupe 2-Door / 2.4L 2389CC l4 GAS DOHC Naturally Aspirated Base Hatchback 2-Door / 2.4L 2389CC l4 GAS DOHC Naturally Aspirated 223 Uncertain about compatibility ask us! 1991 Toyota Celica ST Coupe 2-Door / 1.6L 1587CC l4 GAS DOHC Naturally Aspirated 224 Uncertain about compatibility ask us! 1991 Toyota Supra Base Hatchback 2-Door / 3.0L 2954CC l6 GAS DOHC Naturally Aspirated Turbo Hatchback 2-Door / 3.0L 2954CC l6 GAS DOHC Turbocharged 225 Uncertain about compatibility ask us! 1991 Toyota Tercel DLX Sedan 2-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated DLX Sedan 4-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated LE Sedan 4-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated STD Sedan 2-Door / 1.5L 1456CC l4 GAS SOHC Naturally Aspirated 226 Uncertain about compatibility ask us! 1990 Acura Integra RS Hatchback 3-Door / 1.8L 1834CC l4 GAS DOHC Naturally Aspirated 227 Uncertain about compatibility ask us! 1990 Ford F-150 XL Extended Cab Pickup 2-Door / 4.9L 300Cu. In. l6 GAS OHV Naturally Aspirated 228 Uncertain about compatibility ask us! 1990 Ford F-250 XL Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated 229 Uncertain about compatibility ask us! 1990 Ford F-350 XLT Lariat Crew Cab Pickup 4-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated 230 Uncertain about compatibility ask us! 1990 Honda Prelude Si Coupe 2-Door / 2.1L 2056CC l4 GAS DOHC Naturally Aspirated 231 Uncertain about compatibility ask us! 1990 Infiniti M30 Base Coupe 2-Door / 3.0L 2960CC 181Cu. In. V6 GAS SOHC Naturally Aspirated 232 Uncertain about compatibility ask us! 1990 Mazda 929 Base Sedan 4-Door / 3.0L 2954CC V6 GAS SOHC Naturally Aspirated 233 Uncertain about compatibility ask us! 1990 Nissan 240SX SE Hatchback 2-Door / 2.4L 2389CC l4 GAS SOHC Naturally Aspirated 234 Uncertain about compatibility ask us! 1990 Toyota Celica All Trac Hatchback 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged GT Coupe 2-Door / 2.2L 2164CC l4 GAS DOHC Naturally Aspirated GT Hatchback 2-Door / 2.2L 2164CC l4 GAS DOHC Naturally Aspirated GTS Hatchback 2-Door / 2.2L 2164CC l4 GAS DOHC Naturally Aspirated ST Coupe 2-Door / 1.6L 1587CC l4 GAS DOHC Naturally Aspirated 235 Uncertain about compatibility ask us! 1990 Toyota Supra Base Hatchback 2-Door / 3.0L 2954CC l6 GAS DOHC Naturally Aspirated Turbo Hatchback 2-Door / 3.0L 2954CC l6 GAS DOHC Turbocharged 236 Uncertain about compatibility ask us! 1989 Acura Integra RS Hatchback 3-Door / 1.6L 1590CC l4 GAS DOHC Naturally Aspirated 237 Uncertain about compatibility ask us! 1989 Ford F-150 XL Extended Cab Pickup 2-Door / 4.9L 300Cu. In. l6 GAS OHV Naturally Aspirated 238 Uncertain about compatibility ask us! 1989 Ford F-250 XL Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated 239 Uncertain about compatibility ask us! 1989 Ford F-350 XL Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated 240 Uncertain about compatibility ask us! 1989 Honda Prelude 2.0 Si Coupe 2-Door / 2.0L 1958CC l4 GAS DOHC Naturally Aspirated 241 Uncertain about compatibility ask us! 1989 Mazda 929 Base Sedan 4-Door / 3.0L 2954CC V6 GAS SOHC Naturally Aspirated 242 Uncertain about compatibility ask us! 1989 Nissan 240SX SE Hatchback 2-Door / 2.4L 2389CC l4 GAS SOHC Naturally Aspirated XE Coupe 2-Door / 2.4L 2389CC l4 GAS SOHC Naturally Aspirated 243 Uncertain about compatibility ask us! 1989 Toyota Celica All Trac Hatchback 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged GT Convertible 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated GT Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated GT Hatchback 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated GTS Coupe 2-Door / 2.0L 1998CC l4 GAS DOHC Naturally Aspirated GTS Hatchback 2-Door / 2.0L 1998CC l4 GAS DOHC Naturally Aspirated ST Coupe 2-Door / 2.0L 1998CC 122Cu. In. l4 GAS DOHC Naturally Aspirated 244 Uncertain about compatibility ask us! 1989 Toyota Supra Base Hatchback 2-Door / 3.0L 2954CC l6 GAS DOHC Naturally Aspirated Turbo Hatchback 2-Door / 3.0L 2954CC l6 GAS DOHC Turbocharged 245 Uncertain about compatibility ask us! 1988 Acura Integra RS Hatchback 3-Door / 1.6L 1590CC l4 GAS DOHC Naturally Aspirated 246 Uncertain about compatibility ask us! 1988 Chevrolet Caprice Base Sedan 4-Door / 4.3L 262Cu. In. V6 GAS OHV Naturally Aspirated Base Sedan 4-Door / 5.0L 305Cu. In. V8 GAS OHV Naturally Aspirated Base Sedan 4-Door / 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated Base Wagon 4-Door / 5.0L 305Cu. In. V8 GAS OHV Naturally Aspirated Classic LS Brougham Sedan 4-Door / 5.0L 305Cu. In. V8 GAS OHV Naturally Aspirated Classic Sedan 4-Door / 5.0L 307Cu. In. V8 GAS OHV Naturally Aspirated 247 Uncertain about compatibility ask us! 1988 Ford F-150 XL Extended Cab Pickup 2-Door / 4.9L 300Cu. In. l6 GAS OHV Naturally Aspirated 248 Uncertain about compatibility ask us! 1988 Ford F-250 XL Standard Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated 249 Uncertain about compatibility ask us! 1988 Ford F-350 XL Extended Cab Pickup 2-Door / 7.3L 445Cu. In. V8 DIESEL OHV Naturally Aspirated 250 Uncertain about compatibility ask us! 1988 Honda Prelude 2.0 Si 4WS Coupe 2-Door / 2.0L 1958CC l4 GAS DOHC Naturally Aspirated 251 Uncertain about compatibility ask us! 1988 Mazda 929 Base Sedan 4-Door / 3.0L 2954CC V6 GAS SOHC Naturally Aspirated 252 Uncertain about compatibility ask us! 1988 Toyota Supra Base Hatchback 2-Door / 3.0L 2954CC l6 GAS DOHC Naturally Aspirated Turbo Hatchback 2-Door / 3.0L 2954CC l6 GAS DOHC Turbocharged 253 Uncertain about compatibility ask us! 1987 Acura Integra RS Hatchback 3-Door / 1.6L 1590CC l4 GAS DOHC Naturally Aspirated 254 Uncertain about compatibility ask us! 1987 Ford LTD Crown Victoria S Sedan 4-Door / 5.0L 302Cu. In. V8 GAS OHV Naturally Aspirated 255 Uncertain about compatibility ask us! 1987 Ford Thunderbird Base Sedan 2-Door / 3.8L 232Cu. In. V6 GAS OHV Naturally Aspirated 256 Uncertain about compatibility ask us! 1987 Honda Prelude Base Coupe 2-Door / 1.8L 1829CC l4 GAS SOHC Naturally Aspirated 257 Uncertain about compatibility ask us! 1987 Toyota Supra Base Hatchback 2-Door / 3.0L 2954CC l6 GAS DOHC Naturally Aspirated Turbo Hatchback 2-Door / 3.0L 2954CC l6 GAS DOHC Turbocharged 258 Uncertain about compatibility ask us! 1986 Acura Integra RS Hatchback 3-Door / 1.6L 1590CC l4 GAS DOHC Naturally Aspirated This product is warehoused in California, USA. We will be shipping out the item within 1 business day. If you make an order and pay before 1 pm PST on business day, we will most likely ship out the item the same day! USPS is our preferred carrier. The item usually arrives within 1-5 days after shipped. Other faster shipping option is available on request with additional cost. Email us for pricing to your zip code/country. We ship to PayPal confirmed address only. Please make sure your PayPal address is up-to-date. We accept PayPal only. Please pay within 2 days after buying the item. We only sell new aftermarket auto parts. All our auto parts come with 90 days manufacturer warranty. We take pride in providing quality product and great service to all our customers. We will not refund any labor costs in incurred by you or the installer of the products purchased at this website SanlongParts is an aftermarket auto parts retailer, specializing in both replacement and SEMA parts. We have established great business partnership with manufacturers from around the world to provide quality aftermarket products at a very competitive price. We are here to serve you, our customer! Drop us an email using the contact seller link if you have any question before or after purchasing any item. Please include the eBay item number in all communications. Your satisfaction is guaranteed or you could return the item with no question asked. Let us know if you have any concern on the items. We will try our best to resolve any issue for you. THANK YOU in advance for your great feedback to us! We maintain a standard 14 days return policy. Buyer pays return shipping cost. You must contact us to request a Return Authorization Number (RA#) before you send anything back. Any packages returned by buyer Without Communication WILL NOT be handled. With RA#, we may address return issues with high efficiency. Without RA#, we may fail to find your transaction. Appreciate your understanding! We will resolve any issue for our buyers. Please do not hesitate to contact us through eBay contact seller link for any issues or questions.
IF YOU ARE INTERESTED IN THIS PRODUCT, CLICK HERE TO BID OR TO BUY IT NOW
1 - 1 of 1 Posts
