1 - 3 of 3 Posts
I have experienced Lopeing At freeway speeds and hills/underload with my '80 manual 20r. Drives fine around town but the hill on the freeway going to work is a killer. I have put a new fuel filter, fuel pump, Weber carb, distributor, plugs wires, Ignition control module. And still nothing has changed. It has to be something simple. I have a dual port vacum advance and only one spot on the Weber, thats what I was thinking, the timing is not advancing as the gas increases so that causes the lopeing, but I really don't know:headbang: I have the hose on the vaccum advance side of the dashpot and capped the other. Also if i pull on the manual choke it helps for a few seconds then makes it worse.
84 toyota pickup 2wd
Have you tried changing the spark plugs or ignition coil?
Corona is gone.
86 Pickup
What do you mean by 'loping'?
1 - 3 of 3 Posts
