1 - 5 of 5 Posts
I Have a 22R-TE that just spit its head gaskit. If someone wants to trade for a 22re that would be great. Any offers would be appreciated. Turbo will go with motor. The tranny/tranfer case and rear diff have already been installed in my trail rig.
I have a trail rig that I want to convert from a 22r to a 22re. I would also like to know any problems that I might face with this conversion. Should be pretty easy,the only difference is the intake and computer.
:naughty:
don't forget the fuel pump/lines/filter. mechanical fuel pump used on 22r is far from adequate for the pressures needed for EFI. Probably easiest to get used tank with pump. existing filter will explode under the new pressure, need to replace. and there are two fuel lines - feed and return - existing line may or may not take the pressure.
dave
Trailer Trash Engineer
What year is the 22RTE? I've got an 87 22RE here.
1 - 5 of 5 Posts
